Newest updated spark plug
Old May 16, 2017 | 05:10 PM
waldreps's Avatar
waldreps
I've got a 2004 F150 Lariat 4x4 with the 5.4 engine. I just want to make sure I get the correct spark plugs which are the newest updated ones so they don't break in the future. Is the Motorcraft SP-515 the correct plug? RockAuto doesn't list that plug for my truck so I wanted to make sure. Also, what's the correct COP number? Is that DG511 and are all 8 the same number? Thanks for the info.
Old May 17, 2017 | 03:59 PM
wheelerfreak's Avatar
wheelerfreak
The 515's are the latest plugs. I just replaced mine about 2 months ago. Have you done the plugs and are you familiar with the procedure?
Old May 18, 2017 | 10:51 AM
projectSHO89's Avatar
projectSHO89
You would be best advised to visit Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com and use your VIN to get the correct part number.
2004 was a transition year and there are potential variables concerning build date as well as the engine code that need to be considered.
Old May 18, 2017 | 11:03 AM
waldreps's Avatar
waldreps
projectSHO89, I did look mine up using the VIN and it gives four different plugs. Two that apparently fit the Heritage version(which mine is not) cause they look like a normal plug without the long extension part to it and then two that have the long extension part. One of the them was the SP-507. I've read more and am pretty confident that the SP-515 is the replacement for the SP-507. You'd think with my VIN that it would give me the exact plug instead of including others. That's why I asked on here.
wheelerfreak, thanks. I have never replaced the plugs but have read on here a lot about it. My truck has 225,000 miles so I'm hoping that the updated plugs were used when they were last replaced...whenever that was I'm not sure.
Old May 24, 2017 | 02:56 PM
nddragon01's Avatar
nddragon01
Originally Posted by waldreps
...My truck has 225,000 miles so I'm hoping that the updated plugs were used when they were last replaced...whenever that was I'm not sure.
Jeezus. My prayers are with you.
My advice - if you think you've read enough about the spark plug change, keep reading.
An interesting problem I came across attempting to get the socket on some of the plugs when I did mine in the winter: https://www.ford-trucks.com/forums/1...ut-advice.html
Also I stripped most of the bolts that hold the COPs in place when removing them since they were so rusted. They were fun to remove and had to get new ones after using an extractor nut to get them out. Be careful literally from start to finish.
Dresser77502
2004 - 2008 F150
Jul 29, 2020 06:09 PM
Spindoctor
2009 - 2014 F150
13
Jul 20, 2019 04:06 PM
V8EXPLR
2004 - 2008 F150
Jan 9, 2012 01:51 AM
wkp
2004 - 2008 F150
Feb 20, 2007 10:22 PM
