Which Plug Part Number?
Old Nov 29, 2011 | 02:22 PM
V8EXPLR's Avatar
V8EXPLR
Okay, getting ready to attempt the spark plug change on my 2006 F150 5.4L FFV with 41K miles this weekend. I'm wanting to keep with the Motorcraft plugs, but getting different results. I've searched here, and everyone appears to be using various different brands and part numbers. So which am I to use? This is what I've found from a couple sites.
Motorcraft website for my VIN calls for SP507.
Summit website by year/make/model/motor (no option for FFV) calls for SP515
RockAuto website, only lists Autolite and Chamption plugs for FFV's, but has the SP515 for non-FFV 5.4L's.
Okay, I see that RockAuto has the SP507 listed as platinum, and the SP515 as double platinum. What's the difference? Should I just opt for the Champion plugs, even though I've never been a fan of Champion plugs?
Old Dec 22, 2011 | 03:44 AM
2006 F-150 FordSter's Avatar
2006 F-150 FordSter
hey go to summitracing.com or ford.com and type your engine size and it gives you results
Old Dec 22, 2011 | 01:20 PM
tooldad's Avatar
tooldad
I have the 5.4L FFV and Ford online calls for the SP507, however, the dealership said the SP515 was the appropriate plug, which I installed 11 months ago. There's much dicussion on the forum in regards to sspark plugs, including which part number. My recollection is that folks say the SP515 replaced the SP507 (new and improved?).
Old Dec 26, 2011 | 04:00 PM
390XR7's Avatar
390XR7
Yes SP515 replaces the SP 507's
Old Dec 28, 2011 | 11:36 PM
aquaman's Avatar
aquaman
If I'm not mistaken, the SP507 were the original plugs which were replaced by the SP509's, and then more recently superceded by the SP515.
When I pulled my original plugs out, they were squealing all the way out because they were so tight.. The SP515's turned freely by hand all the way in which was kinda weird. I think they shrank the diameter due to overly tight fit on the original plugs.
I got my SP515s from Kragens/Oreilly's for $8 each.
Old Jan 8, 2012 | 09:26 PM
PartsPaul62's Avatar
PartsPaul62
Banned
Spark Plug Number
Sure wish this was painted a little higher on the side of the barn.
Old Jan 8, 2012 | 11:22 PM
04fxdwgi's Avatar
04fxdwgi
Sleeve is exact same diameter. Just finished measuring SP507 origional plugs that just came out of my '04 against the brand new SP515's that just went in. 0.395"
Old Jan 9, 2012 | 01:12 AM
ford390gashog's Avatar
ford390gashog
SP515 they are also pretty cheap from kragen at about 7.99 each
You will also need this Amazon.com: Lisle (LIS65600) Broken Spark Plug Remover for Ford Triton 3 Valve Engines: Automotive
And this http://www.amazon.com/OTC-6900-F-150...6093017&sr=8-2
and to make life very easy use this https://secure.concentric.com/kanola...der_late.shtml
The above link includes a special discount code. Which is great as you get two 13.00 cans of kroil for 12.00 shipped to your door!
Old Jan 9, 2012 | 01:51 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
SP507 (PZT14F) replaced by SP515 (PZH14F).
SP509 (HJFS24FP) is still a valid part number, Ford parts depots have over 16,000 available. If it was replaced, the Ford parts depot status would be ZERO.
waldreps
2004 - 2008 F150
May 24, 2017 02:56 PM
shore
1997 - 2003 F150
Jan 22, 2014 05:26 PM
jeffk14
2004 - 2008 F150
Aug 14, 2010 06:42 PM
wkp
2004 - 2008 F150
Feb 20, 2007 10:22 PM
plaid311
1997 - 2003 F150
Jan 17, 2006 08:31 AM
