So I finally got the truck(2003 F250 SD) running after a long diagnosis for a weak fuel pump. Went out this am to start it and I find I have no response from the diagnostic port and the left signal is constantly on. I'm unsure as to how the could possibly be related. Ive checked my scanner (SG2) on another vehicle and it is working. Not sure where to even start.
PS Had a earlier post where I had a warning buzzer going off and staying on but I believe that was the signal flasher attempting to close, and cycling constantly.
But the data port worked.
Power to the lighter is good...now and the OBD is working again.
Must be a coincidence and the signal lite switch has gone kaput because now my High beams are on with the key off as well.
