OBS 7.3PSD MAP sensor unplug..?
Old Sep 6, 2021 | 09:56 PM
z31freakify's Avatar
z31freakify
Originally Posted by AuF250
Baro sensor is built into the PCM board from memory. There is no dedicated BARO sensor on the truck, eg in the engine bay.
Easy way to check this issue would be take red line off and plug it. Run like that and see.. if that red line isn't connected it cant pull the waste gate and blow off the turbo pressure. If the truck runs fine without it then it's possible the MAP sensor is reading wrong , causing the waste gate to open early.
If the truck still runs the same way you have a boost leak somewhere, which IMO it probably is. Check all the boots and see if they are tight and not split.
Check to see if they lined the turbo up properly too, both sides.
you are replying to a 4 year old thread on the 94.5-97 Powerstroke section, none of the info relates to the OBS.
I bet you are another victim of the everscroll, you can turn it of you go to User CP and turn off that option.
Old Sep 6, 2021 | 10:16 PM
96 OBS's Avatar
96 OBS
Originally Posted by knottyrope
read through here since it was at the top. This thread is pretty sad. We all do it but come on don’t be an *** about it
glad we’re on a forum that speaks sense into these people
Old Sep 6, 2021 | 11:14 PM
AuF250's Avatar
AuF250
F*@K ........
Dingo1
Jan 5, 2015 06:59 PM
kornfanjoe
Feb 4, 2013 04:42 PM
rollthecoal
Sep 13, 2012 11:42 PM
radarweaver
6.4L Power Stroke Diesel
18
Oct 27, 2010 04:19 PM
junkyard4
13
Feb 6, 2006 08:42 PM
