Oil Pressure Issues
Old May 20, 2017 | 04:56 PM
Raleigh1's Avatar
Raleigh1
Originally Posted by FMJ.
I just checked the cam specs. Nice !
The lift is higher than the OE lift.
Assuming you have OE springs, I'd strongly suggest getting K32-242-4.
Also, if you're ordering direct from Comp, rather try Summit, as they are at least 10% cheaper !!??
Good luck next weekend !
Ordered from Summit, not OE springs, they were trash. This cam needs much stronger springs. I have Lunati dual springs, 348 pounds if I recall correctly. The stockers were like 58 pounds when we took them out lol
Old May 21, 2017 | 05:36 AM
FMJ.'s Avatar
FMJ.
Good, you're all sorted.
Yeah, LOL @ 58 pounds.
Old May 21, 2017 | 03:49 PM
mark a.'s Avatar
mark a.
All things considered, hydro cams pretty much don't never go over 350 pounds. You will need to check all the obvious, push rod length, coil bind, retainer to guide, rocker clearance, spring install height, piston to valve, etc. I would think that cam would run a single spring with a inner damper.
Old May 21, 2017 | 06:39 PM
Raleigh1's Avatar
Raleigh1
Correction, they are 328 pounds, not 348, that is the spec from Comp Cams, I ordered the Lunati version of the spring since Comp was out of stock at the time I built the engine.
Its been running for 2 years and about 15,000 miles with no issues til I floated this lifter.
So I ordered light weight lifters to help reduce the float and lowered the rev limiter a few hundred RPMs to 4500.
steve42683
May 31, 2005 07:18 PM
boss429
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Dec 17, 2003 01:21 AM
Hausladen
Oct 25, 2001 01:03 AM
GSchretter
Jan 21, 2000 02:14 PM
