Drop in oil pressure
Old Oct 24, 2001 | 08:13 PM
Hausladen's Avatar
Hausladen
I recently had to replace my oil pump because it fell apart and locked up and caused the roll pin in the distributor to break. Anyways after i replaced the pump i had real good oil pressure and now a few months later my oil pressure has dropped down to 10 psi at idle and going down the road. I have installed a manual oil pressure gauge and i get the same reading.
Old Oct 24, 2001 | 08:35 PM
Franklin2's Avatar
Franklin2
Did you look at the main and rod bearings when you replaced the pump? If this engine has alot of miles, large bearing clearances will cause low oil pressure.
Old Oct 25, 2001 | 01:03 AM
knuckles's Avatar
knuckles
islandboy007
Aug 5, 2014 07:24 PM
jeffbradbury7
Jan 19, 2013 08:37 AM
mstepchinski
Sep 17, 2004 04:02 AM
kameronth
15
Jul 27, 2004 10:42 AM
masterkiller214
Jun 26, 2002 02:05 PM
