1977 F700 main seal and distributor
Someone suggested I post this in this forum instead of where I originally did.
I have a F700 1977 with a 391 engine 5spd with 2 spd axle. What type of main seal does the engine have. The modern 1 piece or the old style rope seal. What does one need to do in order to change it. Aside from the obvious oil pan. Also is there an advantage to going with a non governed distributor. I understand you need to add sometype of a bushing if one opts for this route. I already changed the carb to a Edelbrock. Thanks
Regarding the seal, seems like you got most of your answer here:
https://www.ford-trucks.com/forums/1...l#post17186327
It's a two piece, so it's a pull the pan job.
As to the distributor, you know from previous replies that you can't put an FE distributor in there without a bushing.
$45 here. I don't know what you do about the different hex drive size other than change the oil pump to an FE pump. Your pump is probably half or more worn out anyway.
http://www.dscmotorsport.com/Engine/index.htm
You can disable the governor and add a electronic ignition to your current distributor.
Ignitor
Don't rev that thing too much above the governed speed. Ford put the governor on their for a reason.
Ignitor
on
dougx
05-14-2017 06:27 PM
JRB65
12-29-2012 08:11 PM
Old Brown F250
13
03-08-2012 06:01 PM
