Cam bearings
Old Sep 3, 2003 | 08:40 AM
screwy's Avatar
screwy
Cam bearings
Can bad Cam Bearings cause lifter tick?
Old Sep 3, 2003 | 11:16 AM
speedkingf100's Avatar
speedkingf100
Cam bearings
The can maybe cause it indirectly as bad cam bearings can cause low oil pressure which causes a lifter tick
Old Sep 3, 2003 | 11:17 AM
fordfan610's Avatar
fordfan610
Cam bearings
I wouldn't think that would cause it. If they are that worn, then you have some real problems. Could be a lifter going bad, oil pressure problems, bent pushrods, worn rocker arm pivots, etc..
The cam could be worn on the lobes and not lifting enough.
I have also heard exhaust leaks that sound like a lifter tick.
Old Sep 3, 2003 | 01:17 PM
screwy's Avatar
screwy
Cam bearings
it has new lifters, pushrods, rocker arms, good oil pressure about the only thing left in the puzzle is the cam.
Old Sep 3, 2003 | 05:08 PM
DW2455's Avatar
DW2455
Cam bearings
did this lifter noise start as soon as the new lifters were put in are did it just start out of the blue? DW
Old Sep 3, 2003 | 06:34 PM
screwy's Avatar
screwy
Cam bearings
this should explain the beginnings
https://www.ford-trucks.com/forums/s...hreadid=141948
Old Sep 3, 2003 | 06:50 PM
DW2455's Avatar
DW2455
Cam bearings
I went back and read the other thread, first thing is it would be virtually imposible for a wrist pin to come out with out totaly destroying a cylinder. cant happen, and would have destroyed a rod as well. these people are jerkin your string big time, i would call the warenty people and tell them you want a new shop athorized by them and you want it fixed NOW! tell them it wasnt doing this before it went to the shop, and if they refuse you'll be glade to take them to court, id also send this in letter form via certified mail so they have to sigh for it. if you get know responce, then file suite in small claims court, they will have to apear and when they loose they will have to reimburse you for court cost which is only 25-45 in most counties,
file your case for damages and loss of use of the vehicle. DW
Old Sep 4, 2003 | 09:59 PM
screwy's Avatar
screwy
Cam bearings
ya they later found it had nothing to do with the wrist pin. It is at a new shop now and as for loss of vehicle oo well I have a back up. I know most people would be pissed, but I’m a really easy going guy so I’m not the least bit mad just as long as they fix it. The new cam bearings are their latest idea, I figure if I just let them keep going I’ll have a new engine soon.
Old Sep 4, 2003 | 10:11 PM
DW2455's Avatar
DW2455
Cam bearings
I understand being understanding, i dont mean to go down there and go POSTAL on them, but shops get away with this type stuff all the time because innocent people who dont know anybetter get screwed, if you dont hold them accountable for there action then the cycle continues, it'll just be another helpless person on another day. but anway. ggod luck with it. DW
