Throttle surge and stalling issues
Old May 14, 2017 | 02:27 PM
Excursion01Norway's Avatar
Excursion01Norway
Yes sealed bag with Ford logo. Does this link work: Ford 7.3L Powerstroke Diesel Engine CAM Camshaft Position Sensor Grey CPS OEM | eBay
Old May 14, 2017 | 02:51 PM
Walleye Hunter's Avatar
Walleye Hunter
Link works and it looks like one of the two OEM's that Ford sells that works. Next to look for loose connections and frayed wires.
Old May 15, 2017 | 02:37 PM
Excursion01Norway
Update:
It has seemed to me that the engine issues are temperature dependent. One thing that I think I have heard mentioned is that disconnecting fuel bowl heater may be an idea. Did that and started up. No problem. Checked all the wires i could see and touch. Nothing happened when wiggling them. A small drive without issues. A bit early to celebrate I guess. I have also ordered the code scan adapter, so lets see how it goes the next few days. Below a picture of what I guess is the UVCH connection that was mentioned? Looks and feels ok to me
Old May 18, 2017 | 11:40 AM
Excursion01Norway
New update: I trid again to wiggle a few lines/contacts and it seemed the ICP sensor responded. Pulled the contact out and it was wet with oil. I guess it needs to be replaced.
Is it so that the OEM is the only safe choice here as well? I see that the price difference relative to other parts is huge. It is also hard to find OEM part that ships to Norway.
Is this ok: http://store.dieseltruckpartsdirect....or-pigtail-kit
Or this from Delphi is claimed to be the actual OEM: https://www.rockauto.com/en/catalog/...re+sensor,6376
Espen
rideracelivemx7
30
Nov 14, 2012 02:01 PM
BillyBob69
17
Apr 5, 2012 04:14 PM
KH85
Jan 5, 2011 09:03 PM
F250_
29
Nov 5, 2010 09:06 PM
hokie
Feb 24, 2005 10:29 AM
