Truck won't start
Old May 10, 2017 | 06:11 PM
truehaun's Avatar
truehaun
Truck won't start
Hey guys so I've had a 1991 f150 4x4 5.0 302 since November. I went out today and it won't start. It doesn't even crank. I hooked up a battery jump pack and it says that the battery is charged and while its hooked up if I try to start it it still won't crank and the dash beeps louder and quicker. Idk what it could be I would appreciate any help.
Old May 10, 2017 | 06:17 PM
rla2005's Avatar
rla2005
Welcome to FTE!
A little proper grammar would help everyone assist you with your issue.
I have no idea what "the dash beeps loader and quicker sounds messed up" means.
Old May 10, 2017 | 06:30 PM
truehaun's Avatar
truehaun
Originally Posted by rla2005
Welcome to FTE!
Sorry what I meant is when I put the key in and turn it to on the batter reader on the dash says 8 volts and what I meant by beeping is when I open the door we all know it beeps right, but when I put my foot on the brake it gets higher pitched. I cleaned the battery post off. Something in the distributor?
Old May 10, 2017 | 06:33 PM
truehaun's Avatar
truehaun
Also with the jump pack hooked up when I turn the key to on it beeps really fast.
Old May 10, 2017 | 06:34 PM
rla2005's Avatar
rla2005
Check the negative terminal battery connection. Also do the same for the connection at the engine block. Most starting issues are caused by a marginal ground.
Old May 11, 2017 | 11:40 AM
madpogue's Avatar
madpogue
Automatic or manual transmission?
Do you hear any sort of click sound from under the hood when you turn the key to START?
Old May 11, 2017 | 07:36 PM
Clinton Thomas's Avatar
Clinton Thomas
+1 Just had a starting issue with my '95 f150 that was caused by a corroded body ground connection.
Billsinca
Apr 2, 2019 11:09 PM
BenH45
EcoBoost (all engine sizes)
Feb 6, 2017 10:37 PM
JIM ROLAND
Sep 13, 2013 08:06 PM
echo657
1997 - 2003 F150
Jan 22, 2010 10:40 AM
fuelit
Feb 28, 2009 03:19 PM
