Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
12V 10A Source
Old May 14, 2017 | 03:38 AM
Suprawill1's Avatar
Suprawill1
Originally Posted by scott91370
But what is it?
This is the spare tire carrier. Normally, you would have to manually crank it down to release your spare tire.
Old May 14, 2017 | 03:44 AM
Suprawill1's Avatar
Suprawill1
Originally Posted by simonsi
Do you access the spare enough to warrant an electric winch?
Normally no, but my first experience with the manual approach was enough to warrant a change. Long story but 45 minutes to lower my spare due to a damaged shaft was unacceptable. This mod was only $25 more than replacing the shaft.
Old May 14, 2017 | 07:40 AM
wptski's Avatar
wptski
Is that a prefab job and the gearbox designed for some other use? I assume that you have to manually stop the motor in both directions? In way was the OEM shaft damaged?
Old May 14, 2017 | 02:31 PM
Suprawill1's Avatar
Suprawill1
Yes, I fabricated the job using a universal gear motor. You really only have to worry about going up as far as stopping the motor. Going down, the tire will lay flat long before your run out of travel. I plan on incorporating an end travel switch for going up.
The very end of the OEM shaft where you stick the tire iron into to crank it is supposed to be rectangular to mate with the end of the iron. Mine was rusted and rounded out rendering it useless. I had to wedge my hand in between the tire and the bumper with a pair of vice grips to turn the shaft. Because of the lack of space, I could barely get 1/4 turn before re-gripping. With each full 360° turn, the tire lowers just 1/2". That created enough frustration to get the gears turning so to speak.
Old May 14, 2017 | 06:33 PM
simonsi's Avatar
simonsi
Thankfully the Tribute spare is internal...
Old May 14, 2017 | 07:45 PM
Suprawill1's Avatar
Suprawill1
Really! I thought the Tribute, Mariner and Escape were pretty much the same. I definitely thought Ford should have taken the same space the tire fits underneath and make that an inside tub for the spare. Just more stuff to go wrong vs just pulling the tire out of the vehicle.
Old May 14, 2017 | 07:59 PM
simonsi's Avatar
simonsi
Yep - certainly on my 2001 Tribute. Never could see the justification for putting a spare under the car, the only advantage seems to be access if the trunk is full but I'd gladly trade that for no winch arrangement anytime.
Old May 14, 2017 | 08:17 PM
Suprawill1's Avatar
Suprawill1
Agreed! ^ ^ ^ ^ ^
Old May 14, 2017 | 09:11 PM
scott91370's Avatar
scott91370
Clever! We had the Tribute which had the spare inside under the floor, that's what had me confused.
Old May 14, 2017 | 09:41 PM
Suprawill1's Avatar
Suprawill1
If the Escape had the same design, it would have saved me time and money. Consider yourself blessed.
Old May 15, 2017 | 06:45 AM
wptski's Avatar
wptski
Might have a sloppy mismatch to begin with. Just like many fasteners these days, either they are undersized or brand new sockets are!
crossy
Feb 1, 2015 11:03 PM
outlaw
Jun 3, 2011 10:17 PM
jdmcivic23
1983 - 2012 Ranger & B-Series
Oct 31, 2010 08:22 AM
nitrogen
Apr 29, 2008 08:07 AM
98_explorer_owner
Jan 27, 2002 03:18 PM
