OT--Third brake light possibility
Old May 9, 2017 | 09:26 PM
49f3dls's Avatar
49f3dls
One of the guys on the Studebaker forum posted this it may be a good way to add a 3rd tail light to your trucks.
Can be seen on this from: http://www.brakeflasher.com/brake.htm
It works with 6 or 12 volts and positive or negative ground. What is really nice is that it can be adjusted to flash, then go steady. It suction cups to the rear window and has a quick connect plug so is easily removed for shows. Very bright and the flashing feature really grabs your attention. It is a bit pricey at $68 but the added safety factor is well worth it. Very simple hook up - one wire to the brake switch and the other to ground
Old May 9, 2017 | 09:28 PM
BTclassics's Avatar
BTclassics
Page Not Found
I've been thinking about adding a third brake light so curious what this one looked like.
Old May 10, 2017 | 07:15 AM
49f3dls's Avatar
49f3dls
BT try it again it originally didn't have the "htm" at the end I just tried it and it worked
Old May 10, 2017 | 07:22 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Here is mine and it was only about $12.00 on Ebay (made is China but it works fine).
Old May 10, 2017 | 08:37 AM
49f3dls's Avatar
49f3dls
Vern is it 6 volt as well as 12? either positive or neg ground? $12 bucks is a lot better than $68 that's for sure.
Old May 10, 2017 | 08:53 AM
abe's Avatar
abe
Several years ago I was on the hunt for a third brake light. The LED lights that were 6 volt negative ground were too expensive, so I made my own out of an old turnsignal. It is held in place by a suction cup I got from one of those Christmas candles you put in your windows. I really haven't used it as I felt reluctant to splice into my brake light. The pic of it lit is with the power coming directly from the battery. For a ground I used a short wire to a screw on the back wall of the cab. So you can see I used bullet connectors for ease of removal.
Old May 10, 2017 | 09:32 AM
GreatNorthWoods
The one I used is 12V negative ground. I've seen some 6V versions but they are more expensive. Here is one like I used...
Universal Car 24 LED Stop Rear Tail Third Brake Signal Lamp Warning Bar USA | eBay
Old May 10, 2017 | 09:37 AM
GreatNorthWoods
Here's one that's 6 volts positive or negative ground but it's $30.
6V only Red 28Pcs Red LED Third Brake Light | eBay
Old May 10, 2017 | 09:43 AM
abe's Avatar
abe
That's not a bad price but it looks like you have to screw the base into something.
Old May 10, 2017 | 10:21 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
I bought two LED round chrome base lights that insert into the rear of the bed rails and can be tied into the other tail lights. Sorry no pictures.
Old May 10, 2017 | 06:20 PM
eman92082's Avatar
eman92082
I wanted something Old-School and intended to mount a Shoebox Taillght until I discovered they weren't symmetrical. After more fruitless searching I thought, maybe a matching 3rd Brake Light?
Once mounted, I thought it was a bit weird but I've come to like it. Unlike my Taillights, it's an LED unit.
Old May 11, 2017 | 04:59 AM
GreatNorthWoods
That works!
Old May 11, 2017 | 05:05 AM
GreatNorthWoods
Here's a 6V that fastens with adhesive tape for $29.95...
Old May 11, 2017 | 05:43 PM
49willard's Avatar
49willard
I installed a tow hitch so I bought mone that plugs into the hitch and the harness.
jondokken
May 14, 2019 10:23 AM
93MARKIII
17
Jun 4, 2010 12:46 AM
broncobillyII86
Bronco II
Mar 10, 2006 07:01 PM
har113
Electrical Systems/Wiring
Feb 5, 2005 10:31 PM
jvidul
1983 - 2012 Ranger & B-Series
Aug 12, 2003 10:41 PM
