pedal boots
Old May 7, 2017 | 05:10 PM
pbsdaddy's Avatar
pbsdaddy
pedal boots
I am installing a shifter boot that will cover the carpet edges and help make the interior look finished. The shift lever is stock, so a tall boot was in order.
Now I am thinking I would like to do the same, for the same reasons, at the pedals.
I'm thinking something like these cheapies might just fill the bill. Opions and suggestions, please.
https://shop.advanceautoparts.com/p/...FcWKswodq3wCng
Old May 7, 2017 | 08:11 PM
FortyNiner's Avatar
FortyNiner
I don't see an issue provided that they don't impede the pedal travel. Since the boots are intended for shifter duty, their durability under compression isn't assured.
Old May 8, 2017 | 05:17 AM
pbsdaddy's Avatar
pbsdaddy
The pedal travel was my only issue. But, you make a good point.
Old May 8, 2017 | 12:35 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Two of those at 4"x5" will look very strange and cluttered in my opinion.
Old May 8, 2017 | 06:01 PM
pbsdaddy's Avatar
pbsdaddy
Another good point. In fact, they might even lay one over the other.
It might be time to go back to the< "pics of what others have done" section.
Old May 10, 2017 | 11:59 AM
petemcl's Avatar
petemcl
I agree with Dave. The part that you suggest might seem strange when used in tandem. I have the same concern with my truck but I have an original accelerator pedal boot that I plan to use. It is much smaller. (See part #2 "Seal-Pedal rod to floor" in the attached LMC drawing)
Or why not use the original seal plate assembly? I have all the metal parts (part #18) if you need them.
Old May 10, 2017 | 08:50 PM
pbsdaddy's Avatar
pbsdaddy
Thanks Pete. I have the seal plate. But the carpet covers it. I hadn't thought of using it over the carpet. But, having it copied in stainless may be an avenue. As a last resort, I may just stitch up the edges on the carpet.
My goal was to add a touch of chrome, that matched my new shifter boot.
I am now looking at having a piece of sheet stainless stamped, to encompass both pedals, and having a dual boot made of leather or vinyl. But, it's looking like the cost may far exceed the boundaries of a, "nice to have" item.
Old May 11, 2017 | 10:24 AM
burnettd01's Avatar
burnettd01
Stainless brake and clutch pedal floor trim
How about stainless trim from Streetrodhq.com?
Hope this helps
Dan
Old May 11, 2017 | 07:49 PM
pbsdaddy's Avatar
pbsdaddy
Hope this helps
Dan
That is probably just what I have been looking for. I'll have to take some measurements, to see just what size hole I actually need, (shaft size, arc, etc), but they look good. Thanks
Old May 11, 2017 | 08:25 PM
burnettd01's Avatar
burnettd01
Pedal boots
There may be more places that sell this type of thing.
Search the web to see what's available.
Glad I can help.
Dan
DGMFORD
Nov 11, 2012 01:31 PM
Dr G
Nov 22, 2009 04:18 PM
cars2cool
Jun 16, 2008 09:02 PM
CruisnPhantom
Feb 14, 2004 09:04 AM
GammaDriver
Jan 14, 2002 12:13 AM
