Compression check
Old May 14, 2017 | 02:12 PM
PapaBearYuma's Avatar
PapaBearYuma
Originally Posted by Filthy Beast
So, I guess I get no answer to my question as to why one should "NEVER fire it up with the compression tester on it".........Mebbe 4 days is not enough time?
But, thanks CelticOne for the reponse.
Maybe one doesn't want to run the engine with the throttle blocked open? Or it's hard to run the engine with all the plugs pulled out? Or it's difficult to discern how many revolutions are required to raise the compression to the maximum pressure? Maybe a hot engine is harder to work on? Maybe a running engine, oiling the rings, gives a false reading?
I don't know the reason, but I think whatever method is employed, its most important that one is consistent across cylinders
Old May 15, 2017 | 09:51 AM
HoustonDave's Avatar
HoustonDave
Just got back onto the forums today... think the question has been answered pretty thoroughly by Tedster and Celtic1. By the way, FB, for folks who stop by infrequently, four days may indeed not be sufficient time, especially since if fte doesn't tell someone there is a specific question pending.
Old May 15, 2017 | 03:23 PM
Filthy Beast's Avatar
Filthy Beast
Mebbe so...but Tedster9's response was as to how to do the test, not so much as why one way is better than the other. CelticOne answered as to a probable why, as did PapaBearYuma (with a bit of humor). But it seems to me one would get gas (carb at WOT) and oil in the cylinders with all the plugs pulled without starting the engine up for a second or two as one would with running the engine for a second or two.
I would think there would be a better definite reason as to why pulling the plugs, disconnect the coil (understood for safety), carb at WOT and counting the engine's revolutions other than, "This is the way I was taught."
No offence, Houston Dave and I'm not trying to be a wise apple...but as in checking/setting, say, the gap on pistons rings, the why would be "If the rings aren't gapped to specs, they'll be too tight and you run the risk of broken rings, broke ring lands, etc,"....."not gap the rings to specs."
This is just a curiosity on my part....
[QUOTE} By the way, FB, for folks who stop by infrequently, four days may indeed not be sufficient time, especially since if fte doesn't tell someone there is a specific question pending.[/QUOTE]
Understood and agree....no problems
Old May 15, 2017 | 03:50 PM
HoustonDave
Been a VERY long time since I was taught to run a compression test but I was told that consistency in testing was important, and you only want to turn so many times for each reading. Having the engine running gives you an indeterminate amount of turns. I suspect having the engine running wide-open with the tester screwed in could potentially damage the tester, as the diaphragms in them probably only take so much pressure and maybe that could be exceeded. You might re-read Tedster's comment, he actually has more 'why' than 'how.' I am far from an authority.
Depends to some extent what info you are looking for. You could probably run several tests: with the coil wire off and removing only one plug removed at a time, both hot and cold. All plugs removed, hot and cold. Squirting oil in each cylinder to see whether any low readings were due to rings, hot and cold. As you said, a compression test is a rough test and other diagnostics like a bleed down test will probably give more complete data: but an initial compression test can give surprisingly accurate indicators of where to go next.
Old May 15, 2017 | 04:11 PM
Filthy Beast
Thanks for the response, Dave.
But I'm not saying to run the engine at WOT....just running for a few seconds. The WOT is for all plugs pulled and coil disconnected.
I agree that consistency - within 10%-20% is ideal and a good starting point. I'm partial to a leak down test initially, though.
Thanks again
Old May 15, 2017 | 04:49 PM
HoustonDave
was referring back to "carburetor choke and throttle plates blocked open."
At an idle you would not be WOT, obviously... I have seen a running compression test referred to as a tool, but like I said, when I was taught a running test was considered a no-no. YMMV. I still like to change dinosaur oil every 3,000 miles, too.
Old May 15, 2017 | 05:30 PM
Filthy Beast
Ahh, hehe....I change mine once a year whether needed or not...generally 5 - 6K miles. Amsoil synthetic with the ZDDP in it.
fordf348
Apr 28, 2014 08:02 AM
GoF700Go
Large Truck
Oct 21, 2012 12:55 AM
mountainman47
Aug 28, 2010 09:44 PM
reamer
Jan 5, 2005 10:15 PM
62pounder
Nov 13, 2000 08:24 PM
