226 no spark
Old Apr 26, 2014 | 06:09 AM
fordf348's Avatar
fordf348
226 no spark
getting the truck ready for Truckstock I changed out the wire from the coil to the distributor, it was running fine, now I have no spark. I put the old wire back on and still no spark. Any suggestions?
Ed
near Philadelphia
Old Apr 26, 2014 | 07:16 AM
bobj49f2's Avatar
bobj49f2
I had a problem some time back with wire inside the distributor. The truck was running fine, dove it to an event and when I came out it wouldn't start. Had to pull it to my shop and found the wire was.bad.
Old Apr 27, 2014 | 06:56 AM
38 coupe's Avatar
38 coupe
Which wire from the coil to the distributor? Is this the coil to distributor cap wire (looks like a spark plug wire) or is this the wire that runs from the points to one of the threaded terminals on the coil?
Old Apr 28, 2014 | 07:32 AM
fordf348's Avatar
fordf348
It is the wire from the distributor that is a threaded connection on both ends, not the spark plug wire type. I followed Bobs instruction and it is running fine now, seems that when I tightened the wire connection I somehow shorted it to the distributor. I was able to put a piece of electrical tape between the stub bolt and the distributor housing.
Does anyone have a picture of what should actually be there?
Thanks
Ed
Old Apr 28, 2014 | 08:02 AM
bobj49f2's Avatar
bobj49f2
That's an easy but frustrating fix to find.
It's been a long time since I had the problem but I think I found an insulating bushing at my local hardware store.
Joey4420
13
Jun 16, 2015 12:46 PM
jimmielee
Aug 13, 2012 04:49 PM
ericeugunep
Sep 11, 2008 09:39 AM
gweeds
General Automotive Discussion
Aug 16, 2008 12:40 PM
mikenofx2000
Apr 13, 2005 03:05 PM
