instrument cluster issues
Old May 9, 2017 | 03:07 PM
wisk's Avatar
wisk
I just purchased a nice non-computerized used low mile F250 7.3 4x4 and it runs great, but am having instrument cluster issues with it. The speedo shows about 10 mph over my actual speed, the trip meter is going 1.1 mile to every 1 mile I drive and the odometer showed about 60 miles traveled after a 250 mile drive. I have stock tires on it.The other issue is the tach has a mind of its own and runs sometime and stops. The last issue is the front tank reads that it's empty all the time. I think the float may be stuck as all research so far says that a bad fuel sensor will read over full. Will it be a remedy to replace the instrument cluster? Any help will be appreciated. Thanks in advance.
Old May 9, 2017 | 04:15 PM
madpogue's Avatar
madpogue
What year truck?
Old May 9, 2017 | 09:39 PM
wisk's Avatar
wisk
1989 F250, 7.3
Old May 10, 2017 | 12:35 AM
madpogue's Avatar
madpogue
Speedo/odo are mechanical, so those problems are unrelated to the others. Tach is probably bad wiring at the tach sensor on the injection pump cover. Fuel gauge is most likely the float, if it works properly on the other tank.
BaldEagles&Freedom
13
Dec 28, 2018 07:44 AM
itsnotanova
Dec 6, 2018 09:02 AM
timbersteel
Jan 31, 2014 09:50 AM
mooner
May 22, 2011 01:00 AM
xericx
1978 - 1996 Big Bronco
Nov 14, 2002 11:55 PM
