Bad instrument cluster. Stuck on full and wacky tach
Old 11-16-2018, 04:31 PM
itsnotanova's Avatar
itsnotanova
itsnotanova is offline
I have a 2000 F550 with only 57,000 miles and the fuel gauge reads full most of the time and every once in awhile the tach goes dead. I replaced the sending unit already and checked all the wiring and grounds. I eventually took the cluster out of the F550 and put it into my F350. It was doing the same thing in my F350 and the cluster from the F350 worked in my F550. I'm 99.99% sure the cluster is bad. I've called around and most places only fix the speedometer on the 99-01 clusters. No one will fix a non-working fuel gauge. I'm about to tear into it and was looking for advise from anyone who's repaired the circuit board on one of these. I don't want to replace it with one from a junkyard only because I doubt I'll find one with that low of miles
Old 11-18-2018, 01:09 PM
crop harvester's Avatar
crop harvester
crop harvester is offline
bump to the top
Old 11-18-2018, 01:47 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
Go to eBay type in F550 gauge cluster, options will pop up from clusters to repair services. I bought a cluster last Fall off eBay when I couldn’t fix my odometer, it’s worked fine. Regarding changing the mileage... I ONLY changed the far left 2 digits, bigger teeth on the gears so less chance to damage anything.
https://rover.ebay.com/rover/0/0/0?m...2F183375832871
https://rover.ebay.com/rover/0/0/0?m...2F232976785382
Old 11-18-2018, 03:43 PM
pirate4x4_camo's Avatar
pirate4x4_camo
pirate4x4_camo is offline
Very simple to swap the mechanical odometer from your old cluster to the new one, Likewise very simple to swap any of the gauges or even the printed circuit from one cluster to another
Old 12-06-2018, 09:02 AM
itsnotanova
Thanks. I sent it off to a friend who thought he fixed it. Threw it in and still had a problem. I got a used cluster and switched out the odometer from the low mile cluster to the replacement. Real easy.
lolocal
11-28-2018 10:50 AM
Nathan Plemons
06-14-2013 01:56 PM
Diabolic
1983 - 2012 Ranger & B-Series
04-16-2004 04:35 PM
plourde2002
1997 - 2003 F150
01-18-2004 08:41 PM
Quick Reply: Bad instrument cluster. Stuck on full and wacky tach
