Engine Monitors
Old May 8, 2017 | 03:23 PM
Danj2718's Avatar
Danj2718
4wd Low
Engine Monitors
I just recently bought a 2005 Ex with the 6.0L diesel. I also bought an Edge CTS-2 Monitor. Now, my question is this. I am new to diesels and I know the Edge will monitor many engine parameters. I'm asking which parameters are most important to watch and where can I find the limits of those parameters? Thanks in advance.
Old May 8, 2017 | 03:54 PM
LivingLarge's Avatar
LivingLarge
I'll start
For your 6.0 I'd start with these
FICM voltage
Oil temperature
Coolant temperature
Old May 8, 2017 | 04:31 PM
lightflyer's Avatar
lightflyer
rpms, vehicle battery, change out oil temp for the delta PID if possible, trans temp
Old May 8, 2017 | 05:25 PM
IMASAP's Avatar
IMASAP
I'll add EGT and Trans temp.
Also, get a cheap tablet and use it to run Torque Pro as a second monitor.
Old May 8, 2017 | 09:35 PM
EXSwap's Avatar
EXSwap
I run:
coolant temp
oil temp
trans temp
egt
battery voltage
boost
speed (mph)
the last one is a floater I switch back and forth, right now I think it's set to FICM voltage
donovan
6.7L Power Stroke Diesel
15
Jun 18, 2013 04:04 PM
richrob
Feb 15, 2011 08:00 PM
-=Pit=-
Dec 7, 2009 01:32 PM
stroker04
Nov 11, 2006 09:46 AM
