Ampmeter troubleshoot help
Old May 8, 2017 | 07:09 AM
kansas storm 350's Avatar
kansas storm 350
What would cause the ampmeter to stay all the way on charge even when the engine is not running? With the battery disconnected, the gauge reads in the middle like it should. Thanks.
Old May 8, 2017 | 11:19 AM
Filthy Beast's Avatar
Filthy Beast
What happens when you turn the headlights on with the engine off?
This is, of course, presupposing someone hasn't been fiddlin' and diddlin' around in the wiring cicuits....basically stock wiring.
And, do you have a side or rear terminal alternator....or.........?
Old May 8, 2017 | 11:45 AM
meangreen92's Avatar
meangreen92
Could it be overcharging? I'd think a battery explosion would be imminent in that case. Have you checked the voltage?
Maybe only the ammeter shunt is carrying current, and the main route is somehow disconnected?
Old May 8, 2017 | 11:52 AM
kansas storm 350
Rear terminal with one big wire and one small wire. Everything was working prior to the new engine. I picked up a new voltage regulator today to see if that is the culprit.
Old May 8, 2017 | 11:53 AM
Filthy Beast
Rear terminal alternator/regulator connections. Note the shunt wire by the ammeter.
Note that the "I" terminal on the regulator is not used with an ammeter.
Old May 8, 2017 | 12:38 PM
Filthy Beast
Should have 3 connections.....
Pictures?
Old May 8, 2017 | 03:38 PM
kansas storm 350
Only 2 connections.
Old May 8, 2017 | 04:08 PM
Filthy Beast
Looks like you're missing a wire/connection on the far left terminal in your picture.....the one with the black little grommet around the bottom. Think it's the Stator "STA" terminal....goes to the 'S' terminal on the regulator.
Seems like you have the "low mount" alternator....top picture in post #6.
Old May 23, 2017 | 08:40 PM
kansas storm 350
This alternator is still kicking my butt. Ammeter still bouncing around along with the headlights and every other light on and in the truck. The stator wire has never bèen used since I have owned it. Even though the alternator checked out ok at Oreilys, could it be a bad diode? Any other ideas?
Old May 24, 2017 | 06:32 AM
Filthy Beast
The stator wire has never bèen used since I have owned it. Any other ideas?
If that wire is still floppin' around, I would suggest connecting it.
And double check all yer grounds....engine to cab, frame to ground, etc.
ollirrap
Jun 28, 2017 07:12 AM
at38b
Electrical Systems/Wiring
Oct 26, 2013 12:11 PM
ricksta56
26
Apr 10, 2010 01:08 AM
DDuBB
26
May 27, 2006 07:41 PM
NJ239Y
May 22, 2004 07:34 AM
