1978 - 1996 Big Bronco
Difference between 1982 and 1979 bronco frame. Any?
Old May 8, 2017 | 05:00 AM
pat420swed's Avatar
pat420swed
So I need a new frame for my 82 bronco and I've found a cheap 79 going for parts near me that's got a good frame on it, and I'm wondering if this would be a straightforward body swap or will I run into some problems, anyone done this before? Thanks
Old May 8, 2017 | 05:10 AM
pat420swed's Avatar
pat420swed
I should mention too that it's already got a 1979 five bolt solid front axle swapped in it which is what I think the 78 and 79 broncos came stock with? And it's a 300 6 with a four speed drive train
Old May 8, 2017 | 03:18 PM
WhëëlMå1's Avatar
WhëëlMå1
I highly doubt it will work. 80 was the transition year, so I am sure it all changed.
Old May 8, 2017 | 03:29 PM
cobrajoe's Avatar
cobrajoe
Just my $0.02, but if you know anyone at the boneyard, ask them to check on the parts interchange.
Old May 8, 2017 | 11:30 PM
1985 Bronco's Avatar
1985 Bronco
The 79 frame is very different
Old May 11, 2017 | 08:38 AM
pat420swed's Avatar
pat420swed
I've found a 1992 bronco being parted out with a good frame, are the 90s frames identical to the early 80s frames? Or close?
Old May 11, 2017 | 04:19 PM
AbandonedBronco's Avatar
AbandonedBronco
The body of the Bronco only changed cosmetically between 1980 and 1996. There may have been some subtle design differences, but nothing major.
martins2141
Feb 21, 2011 05:55 AM
1986_F150
Dec 1, 2005 07:24 AM
reamer
Jan 19, 2005 11:19 AM
rayner601
Jul 7, 2003 02:25 AM
dslman
Jul 14, 2001 01:01 AM
