Ford Diesel
Ford Diesel
Hey I am looking at getting this truck to use to haul with, I don't know much more about it than that it an 80-94 F800 with a diesel motor. The owner would be letting it go cheap which is why I'm looking at it. Are the motors in these trucks any good? I was reading that it could be either a 6.6, 7.8, or a 7.0. If the truck is going to be a big hassle I'd rather know now before I get it. Also when I go look at the truck is there anything that I should make sure to look for? Any common problems with these trucks?
Cool looking truck. Post the VIN and we can decode it for you. Post the whole door tag and we can tell you a whole lot more about the transmission, axle, paint and body.
The year matters in terms of which version of which motor, that can make a pretty big difference in getting parts and working on them.
The full air brakes are far more reliable and cheaper to fix than the hydraulic I'm told.
Air brakes might require a test and endorsement on you license. See your state DMV /driver licensing web site for the correct answer.
Having said that, I would expect an F800 to have a GVWR greater than 26000.
I am betting on 8.2 Detroit. Has 30,000 gvw at the least. Looks like still riding on 10.00-20s which are hard to come by. Cant tell if single speed or 2 speed R/A. Proably why cheap is engine is no good and you really don't want fix that 8.2. Parts are hard to get. I know I am running one in a 83 800 with hyd brakes. Chasing engine oil leak now.
Not to worried about the tires, I can get them by the pallet, just cost about 300 per tire, my other trucks still run 8.25-20 and 9-20. I've heard that the 8.2's are a pain. Also I kinda want to pick it up for the cab. Crew cabs are getting hard to find and that one would be a good one to swap onto a pickup truck.
I'd just as well stick with the 10-20's and in Michigan around the farms there are still so many of these trucks that honestly should not be on the road and still are that it's not to difficult to find shops that do split rims and can get the 10-20's, plus you don't have to deal with getting different rims that are 22.5
mb_01sc
07-01-2008 10:37 PM
