Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Vin decode help
Old Aug 18, 2018 | 09:45 PM
mercdiesel's Avatar
mercdiesel
Vin decode help
Just acquired a c series Mercury and don't know year , etc. the door emblems say Mercury diesel. The engine is definitely a 6cylinder Ford diesel. It has bucket seats and a handbrake on the floor instead of on the dash This seems to be all stock.
Vin is 1516035L-178479F. Series is M-C600 wheel base 153.engine/ trans 366C08RHT-5H/D2C53. Trans C0TT7004H rear axle CC3TA400 and front axle 20 C0DE. Any help would be great but need the year for sure.
Old Aug 19, 2018 | 08:23 PM
third66go's Avatar
third66go
VIN 1516035L-178479F probably decodes as:
1 = Gasoline 8 cylinder (if it is really a 7, that would be a Ford diesel)
51 = C600 tilt cab/single rear axle/gasoline
60 = 1965 600 series
35 = 135" wheelbase
L = LH drive
178479 = 1965 model year
F = 19,510 to 26,000# GVW rating group
C0TT7004H = Clark 5-speed trans. model 251-VO-18 (which is applicable to Ford diesel)
20 Code = Ford-Rockwell 7,000# rated front axle
Should be a different engine code on main warranty plate, couldn't find anything on "366C08RHT-5H" (if it is an "E" that would be a Ford diesel),
might look like "E-5' (Ford diesel, 5-spd trans)
This from Ford Parts List, may or may not be the most current info...hope it helps
Old Aug 22, 2018 | 11:43 AM
mercdiesel's Avatar
mercdiesel
Cabover
The wheel base measures 153 like the vin tag says. All of these numbers are off the tag on the door post.
canyoncat
Large Truck
44
Jan 21, 2022 06:56 AM
Woody205510
Large Truck
Apr 8, 2019 12:26 AM
gdoakes
Large Truck
Feb 10, 2017 04:22 PM
Dave588
Large Truck
Jun 4, 2016 11:20 AM
