I have a 1990 f150 5.0 or 302 which ever you prefer. I am going carb I'm tired of this efi bull. I need to know which wires I need to keep and which ones to throw and what's needed please help get blackychan back on the road .
The wires going to your starter can stay, the ones going to the alternator can also and if you can find a wire that is hot in run AND start positions, then keep that one too and use it for your Distributor otherwise just run new wires.. Get an HEI distributor to make it simple
The constant wires busting and everything else relays and fuses. I'm saving some wires off my wiring harness to the coil and the headlights and stuff like that off the speed density harness
EFI is so much better than carb, why in the world would you want to switch?
That question gets asked just as often as the one about ditching the EFI for a carb. Answer is always the same. It is their truck and they can do as they wish.
I agree, going carb is a downgrade, but there must be hundreds of threads on this forum asking the same question. Please use the search and you will find endless detail on this and the problems are not limited to wires.
Its just a bandaid.. and if the rats ate the FI wiring they also ate the body wiring which will not be fixed by going to carb
I don't think these trucks came with the aode, just cars.
Your biggest hurdle if you have an e4od is controlling it. Probably wouldn't even be worth the carb swap.
If you have manual or aod, you just need to iron out a few things such as tachometer signals and the like
I can understand going to carb if rodents ate the harness, but I'd seriously consider sourcing a jy harness and swapping it...it'd be less work and money ultimately and you'd still retain the benefits of efi.
If it has an AOD you'll need to make sure you get the necessary kickdown linkage. Everyone says that an AOD won't last long otherwise. I don't know how it's managed on an AOD behind an EFI engine, but I doubt it's the same parts that would be needed with a carb.
