Trailer harness running lights.
Old May 7, 2017 | 04:16 PM
docsuby's Avatar
docsuby
Hey folks, I've got a 2000 F250 with the tow package. I'm having an issue with the trailer harness running lights. It's not the trailer, works fine on another truck. As far as i can figure, the orange wire from the truck wiring harness powers the running lights. I've go no voltage on that wire, all the fuses are good, everything else works on the harness and the truck. Can anyone point me at the next logical test/failure point? I'm assuming at this point its a broken wire, but I'm not great with vehicle electronics.
TIA!
Old May 7, 2017 | 04:25 PM
alloro's Avatar
alloro
There is a trailer running lights relay in the fuse box (if you have DRLs) and it has it's own fuse, #4 I think. So it could be a bad relay or that #4 fuse.
Old May 7, 2017 | 08:18 PM
Franklin2's Avatar
Franklin2
That fuse he is talking about along with the relay is in the fuse box under the hood.
Old May 8, 2017 | 07:16 AM
projectSHO89's Avatar
projectSHO89
Fuse F4, which supplies power to the relay, is in the underhood relay/fuse box.
The trailer running lamp relay is in the under dash box, not under the hood.
The wire from the relay, all the way to the rear trailer connector, is brown/white.
It is not uncommon for the connections under the body (along the left frame rail) to develop corrosion in one or more pins. It would be worthwhile to, after verifying F4 and the relay as properly operating, to crawl under there and check each of those connectors by unplugging each and inspecting them.
Old May 8, 2017 | 08:24 PM
Franklin2's Avatar
Franklin2
I guess this diagram is wrong then. I have seen mistakes before in these things, even the Ford diagrams.
http://www.revbase.com/BBBMotor/Wd/DownloadPdf?id=69101
Old May 8, 2017 | 09:06 PM
projectSHO89
As have I, multiple times.
Let me do a couple of cross-checks, either the diagram I have or the one you have is incorrect, they both cannot be correct.
Old May 11, 2017 | 10:03 AM
alloro's Avatar
alloro
According to page 3 of the diagram, both fuse 4 and the relay are in the battery junction box.
Old May 11, 2017 | 11:37 AM
projectSHO89
Yes, it does, but it also appears to be the diagram for the Excursion, not the F250. They're not identical.
Use this one for the pickup: http://revbase.com/BBBMotor/Wd/DownloadPdf?id=69129
The relay is in the "IP Relay Block" which also holds the flasher relay. See following thread for the same discussion (and problem).
https://www.ford-trucks.com/forums/1...t-working.html
Old May 11, 2017 | 02:32 PM
Franklin2's Avatar
Franklin2
Thanks for the help.
k3v1n
Electrical Systems/Wiring
May 24, 2011 11:41 AM
wheelz3333
Apr 30, 2009 03:52 PM
prestroke diesel
Nov 7, 2008 11:36 PM
hammer65
Jul 21, 2008 11:02 AM
Mark 42
Mar 8, 2004 01:49 PM
