i need your guys help...
Old Nov 6, 2008 | 09:42 PM
prestroke diesel's Avatar
prestroke diesel
i was on th eroad to pick up a tractor and i noticed the trailer lights were no longer working. it was about dusk so i stopped to look and my tail lights weren't working either. the weird part is that the brake and turnsignals still work but no running lights???? i checked all the fuses a couple were blown i replaced the bad ones but now im out of ideas... i thought maybe it was my switch or something maybe something in the column... who the f*** knows... the lights worked when the dufus at the rental place plugged them in but not anymore... its on a 92 5sp 7.3 someone on here has got to have an idea im lost... im not even stranded anywhere fun im in moses lake washington lol sorry for the long post thanks for any help you can give me you guys are my only hope
Old Nov 6, 2008 | 10:20 PM
KJLYPW's Avatar
KJLYPW
Is your trailer wiring run off of the Ford harness, if so the running lights run off of a relay in the relay fuse box under the hood. The under the dash fuse box should only run the truck lights not the trailer wiring- Unless your trailer wiring was spiced into the truck lights, in which case you may be overloading the truck circut with the tailer hooked up.
Check the fuses in the relay box under the hood. Fuses in there will also supply power to the dash fuse panel. Hope this helps- I had the same thing happen to me, lost all clearance lights- the morning after I hooked up ready to go and checked all good the night before- PITA, took me all morning to track down a liscense plate light socket that had shorted out- kept blowing fuses.
Old Nov 7, 2008 | 05:32 AM
Dodge/Cummins's Avatar
Dodge/Cummins
For some wierd reason there's a fuse IN the wiring AT the driver's side rear tailight. Pull the tailight out and check it.
Might be your problem.
Old Nov 7, 2008 | 09:00 AM
prestroke diesel
kjlypw
so could it be the relay itself? of does it have to be a fuse? i checked all the fuses they are all good could it blowing fuses caused the relay to go out? its the wierdest thing everyone i talked to didn't believe me thanks alot for the input
Old Nov 7, 2008 | 11:26 AM
macman85602's Avatar
macman85602
Not sure about the newer trucks But on the older ones i could be the Headlight switch was over loaded? just a thought
Old Nov 7, 2008 | 11:46 AM
KJLYPW's Avatar
KJLYPW
On my 93, the trailer marker light relay is the second one from the engine side of the box as viewed from the fender! I suppose a shorted out relay may cause the problem.
The other relays in there are the same P/N, so you could swap it with another to check it out. The one closest to the engine is the trailer battery charge relay, so that would be the one to swap with if you have it. Otherwise, they are cheap enough to buy even at Ford- about 7 bucks each as I recall. Good luck- Check for a short in the trailer wiring harness would be my bet.
Old Nov 7, 2008 | 04:52 PM
gonecrazyi's Avatar
gonecrazyi
I had the same problem (Twice), there was a connector on the drivers side rear of the truck that wore out and had come apart. I lost power to the lights but everything else worked. Funny thing is I never blew a fuse.
PS - The second time I was pulled over during bike week (with two old motorcycles in the back of the truck). The cop came over and checked my papers and the bikes. I asked what I had done (I new I wasnt speeding even though my speedometer didnt work!). He told me "youre lights are all out, youre gonna end up with somebody splattered all over the back of your tailgate and I'm gonna be the one thats gonna have to come out and scrape um off." Moral of the story, some off the cops around where I live actually have a sense of humer.
Old Nov 7, 2008 | 09:19 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Tail light wire is brown, also powers the side markers in the bed.
Right and left turn signal which also does the brake lights are green and yellow.
Did the rental place install the trailer wiring on your truck?
What do you have a flat plug or the round one?
Old Nov 7, 2008 | 11:36 PM
prestroke diesel
well good and bad news... i stopped today and bought a new relay from ford for 15 bucks... and it still didn't fix it then i thought oh well ill just drive during the day then i got here to get the tractor and my uncle (who i am hauling it for) decided we better get it fixed so we took it to a shop... and they were stumped a while... it turns out that somewhere ahead of the axle in the frame rail there was some kind of bs wiring job and it had wiggled apart... so they replaced a 8 inch piece for 100 bucks lol well long story short i didn't have to pay for it. so maybe the next time this happens ill know where to look haha thanks a lot for your help i was sure it was a fuse of a relay or something... to bad it wasn't the trailer then we could have gotten the rental for free
p.s. ill post some pictures im sure the loading style will scare some of you lol
sflem849
Aug 7, 2012 07:23 AM
Juette
Mar 6, 2012 09:55 AM
powerstroker02
Oct 6, 2010 11:13 PM
notyettoday
Jun 6, 2005 10:51 PM
Syzle
May 28, 2002 09:55 PM
