Heated mirrors
Old May 7, 2017 | 02:43 PM
Derrick Roberts's Avatar
Derrick Roberts
Heated mirrors
The truck I bought had the "tow mirrors" on it and one was broke so the guy I bought it from put the non tow mirrors on it and I want to know if my truck has heated mirrors or not cause that's that was on it before he changed them out..
Old May 7, 2017 | 02:44 PM
Derrick Roberts
It's a 99 f250 super duty XLT
Old May 7, 2017 | 03:31 PM
Bonanza35's Avatar
Bonanza35
No heated mirrors on a 99. You can add them, some here have done it. They would have to check in to tell you how.
Old May 7, 2017 | 10:32 PM
pirschwagon's Avatar
pirschwagon
Heated Mirrors began in 1988 of the F-Series. The only way to know is to look at the wires in the doors, find the build-sheet, or, sometimes the Dealer can look it up with the last 8# of the Vin. These were optional on Lariats, and could be added to an XLT if an ordered build was requested (along with Cab Marker Lamps $56.00 for the Lamps and $212.00 for the Mirrors).
Another way is to Put the Defroster "ON" and touch the mirror. It will also have a Heater Symbol is equipped.
Adding them is fairly easy. Using Ford Part#: F3TZ18C621B Switch, Defroster, Timed, from a Explorer
The switch is a surface mount. requires cutting hole to dimensions.
Explorer Wiring Diagram. Use this wiring diagram and fuse circuit.
cordus
6.7L Power Stroke Diesel
16
Jan 14, 2015 07:24 AM
quinletc
Sep 10, 2014 08:30 PM
the Goat
Sep 15, 2009 01:18 PM
SUPERDUTY_08
6.4L Power Stroke Diesel
Jun 28, 2007 10:36 PM
79CEEJAY
Nov 25, 2002 05:08 AM
