compression height
Old Sep 2, 2003 | 09:08 PM
hoxiii's Avatar
hoxiii
compression height
I was wondering what the stock compression height for a 300-6 piston is.
Justin
Old Sep 3, 2003 | 05:09 AM
Pkupman82's Avatar
Pkupman82
compression height
If I remember right the compression ratio on a 300 six is 8.5 to 1
Old Sep 3, 2003 | 09:10 PM
hoxiii's Avatar
hoxiii
compression height
I don't need the ratio, i need the compression height, the pin height, the distance from the crown of he piston to the wristpin. I'm looking for a set of flattops for my 300 and i think i've found a set, but i need to know the pin height to be sure they'll work. It's for a carbed '85 if it makes any difference.
Justin
Old Sep 3, 2003 | 09:23 PM
StrangeRanger's Avatar
StrangeRanger
compression height
1.757" comp. height
10.000" deck height
6.2097" conn. rod centers
3.980" stroke
0.0433" deck clearance
Old Sep 3, 2003 | 09:24 PM
Silver Streak's Avatar
Silver Streak
compression height
It's 1.78 give or take a few thousandths. It's the same as a 390, as is the pin diameter. There are probably a dozen pistons for the 300 listed on the KB/Silvolite website, one of which is very close to being a flat top. I have a 300 from a 73 F-100 at my parents house that had flat tops in it from the factory. It might have dishes, but if it does they are very small, maybe 8-10 cc vs. 40 cc for the late model stuff.
Old Sep 4, 2003 | 01:08 AM
tetraruby's Avatar
tetraruby
compression height
SR's math works out. The older 300 rod with the smaller pin (0.912) will work for that of 351W pistons - similar crown dimension too.
Old Sep 4, 2003 | 05:06 PM
hoxiii's Avatar
hoxiii
compression height
That's what i was looking to do, either use an old set of 300 rods or rebuh a newer set to accept the .912 pin. Unless i'm looking in the wrong place it's cheaper to buy the 351 pistons and rebush the rods than it is to buy a set of "performance" 300 pistons.
Justin
Old Sep 4, 2003 | 06:02 PM
tetraruby's Avatar
tetraruby
compression height
Yes, you're right...and there's a better selection too.
Old Sep 4, 2003 | 06:11 PM
Silver Streak
compression height
You should be able to have a set of custom pistons made for under $500. By the time you buy 351 pistons and have the rods bushed or buy early model rods you are going to be pretty close to that anyway and still have an off the shelf piston that may or may not be exactly what you want/need. There was a thread about this issue a while back.
Old Sep 4, 2003 | 08:43 PM
hoxiii's Avatar
hoxiii
compression height
I can rebush my own rods, then pick the set of 351 pistons i want and I won't be anywhere near $500 out.
Justin
Old Sep 5, 2003 | 03:44 PM
wtroger's Avatar
wtroger
compression height
352 pistons are the right diameter and right pin size you have to cut .040 off the top. I looked at this a year ago and have gathered all the parts will build this engine this fall
davistr
Mar 12, 2015 05:05 PM
troy's66customcab
Mar 19, 2011 12:27 AM
monkei
Jan 20, 2009 08:01 PM
1972 Ford Thunderbird 429 V8
Dec 19, 2008 05:42 PM
46yblock
Nov 30, 2006 05:47 PM
