piston compression distance?
Old Mar 19, 2011 | 12:15 AM
troy's66customcab's Avatar
troy's66customcab
Does the piston compression height/distance matter for my 240 I6 ? I found some 302 pistons with 1.605 compression height vs. the 1.585 will they work?
Old Mar 19, 2011 | 12:27 AM
85e150's Avatar
85e150
Add that number to your rod length and 1/2 your stroke, and compare it to your deck height.
How close to the top of the deck were the stock pistons? Is there room for the "extra" in the combustion chamber. (hint-NO)
If the stockers were down the hole and the 302s give you "zero" deck, you might be OK.
Nick-1973-ford
Mar 5, 2017 06:38 PM
7636074460
May 7, 2012 08:58 AM
monkei
Jan 20, 2009 08:01 PM
1972 Ford Thunderbird 429 V8
Dec 19, 2008 05:42 PM
TMI
25
Feb 2, 2006 09:33 AM
