351W stock spec and stroker questions
Can anybody tell me the following for a 1995 351w:
Stock piston compression height?
Stock piston to deck clearance?
And if I could choose between stroker kits of close displacement would I want to go for:
3.75 crank 6.25 rod 1.35 compression height (9.502-((3.75/2)+6.25+1.35))=.027 piston-deck clearance
3.7 crank 6.125 rod 1.485 compression height (9.502-((3.7/2)+6.215+1.485))=.042 clearance
What is a good clearance for good quench with a standard .039-.041" head gasket?
Am I understanding correctly that more compression height on a piston means more skirt and more piston support/better longevity?
And lastly, how much if any larger in diameter should the head gasket bore diameter be than the bore in the block?
As for the last question, I would think ideally the hole in the gasket for the cylinder bore would be just a shade larger than the bore (just enough to not rub the piston). In practice they are made to accomodate the largest anticipated overbore plus clearance to allow for slight misalignment.
393 stroker, youre using a 4.1 gasket on a .030" over motor? Would it be cutting it too close to use a 4.06 bore head gasket with 4.032 bore?
So heres the ideal setup (I think) 3.7 crank 6.25 rod (1.689 rod/stroke ratio) ~1.37 CH piston
The math: (9.502-((3.7/2)-6.25-1.367)=.035 piston-deck clearance
So if I use a .039 gasket I'll have .074" between piston and head at TDC is this too much?? Too little?
The 4.06 gasket must be something special because I only have 4.100/4.160.At .035 you will lose a little compression/quench/power.You want about .005 -deck height.Get John Lingenfelter book on High Performance Engine Building and Tuning for Street and Strip.It`s based on the SBC but there`s alot of good reading/knowledge
Using a 4.06 bore on a cleveland motor is not a good idea because the chamber in the head is bigger than 4.060 and the top of the bores are notched on cleveland block as well.
math is 9.502 minus 5.956, 1.925= 1.621 for compression height and deck clearance.
Check Summit, it seems like the majority of 4.06" head gaskets I'm finding are copper (Will this work for Iron block/aluminum heads?).
The reason I wouldn't want to go with that combo (5.956rod/3.85 stroke) is the short rod/stroke ratio (1.54:1). (Stock is 1.7:1, my combo would be 1.69:1) I'm hoping the lesser rod angles and longer piston dwell will work to my advantage in building torque for a high perf. streetable truck motor and making the engine last longer.
393Stroker, would you recommend that same .005" piston-deck clearance in a 9.5-9.7:1 351w stroker with 72cc combustion chambers?
The copper head gaskets are a good upgrade, but you dont need them unless your running a lot of boost.I have trick flow 61cc heads with the o-ring grooves cut in them for o-ring gaskets.My block has .005 deck clearance becuase thats what the machinest recomended to get some good quench,but you will lose comppression w/72cc heads
brehenkel
12-03-2015 07:45 PM
RatRodAlex
08-21-2015 08:04 PM
lizardman1
03-14-2014 02:43 AM
Alvin in AZ
28
08-09-2009 10:49 AM
1966F100FE352
10-02-2008 08:03 PM
