What's the best aftermarket torque converter to by for the 4r100? I'm not looking to drag race or sled pull. I just want a driveable truck that can handle the little increase in power I've thrown at it. I've got a ts 6 position chip and swamps 175/146 injectors in the truck.
check these guys out. I call a local shop that uses them and was told the return rate on the TQ was almost non existence, .0001% returns.. that was strong and the RPM for stall is lower as needed for good towing.
Triple disk billet.
I had a friend tell me that he had a triple disc torque converter and it was really grabby. To the point where he had to make sure to really hold the brake firmly at a stoplight. Is this how all triple discs are? Is swapping a 5r100 torque converter a decent move?
Not for sure but i think the r4100 and r5100 are same TQ.. the 4 or 5 is number of speeds in trans and the 100 or 1000 is the amount of HP the trans can take.
I believe this was from mark K.. On Hp something about the engine HP being multiplied by a factor of 2 when determining HP to TQ..
So a r4100 is a 4 speed unit capable of handling 1000 HP to drive shaft.
I had a friend tell me that he had a triple disc torque converter and it was really grabby. To the point where he had to make sure to really hold the brake firmly at a stoplight....
A tune might be able to fix this... but I only say that as a question to raise. I totally suck at auto transmission questions - they are black magic and pixy dust to me.
The 100 (1000) refers to amount of input torque the trans is able to withstand, not engine horsepower.
Tuning would be able to do only so much. Lowering idle speed, at engagement, can only be adjusted slightly or there could be engine stall.
The number of clutches doesn't really have a bearing on stall or "grab". It is the design shape, and angle, of the stator and fins that affect trans stall speed. The clutches only come into play at lock up.
Stall is a relative term. The amount of engine torque applied to the trans will vary the stall rpm due the "slippage'' within the torque converter. There is no "one size fit all". Torque converters can act differently with each application. Engines with more low end torque will have a higher stall potential than others. Lighter vehicles will move more easily than others.
The grabby feel is due to either too low of a stall speed or too high of an idle speed. Triple or single disc makes zero difference at idle.
And it's 5R110. There is no 5R100.
No.
It's 4R100 and 5R110. And they are not the same torque converters.
The first number is the number of forward ratios. The letter denotes Front wheel drive or Rear wheel drive. The next numbers refers to the torque rating at the input shaft. This is after the torque multiplication of the torque converter. So the 4R100 is rated for 1000 lb-ft of input torque, and the 5R110 is rated for 1100 lb-ft of input torque.
A tune could lower engine speed, but as mueckster said that may cause stalling. A tune isn't going to go into the torque converter and bend the fins that create the stall speed.
