Sirius update?
Old May 5, 2017 | 07:27 PM
Ferguson65's Avatar
Ferguson65
Sirius update?
Started the truck up tonight, got 5 seconds of radio and then it said Sirus update 0%. Status bar hasn't moved off 0% and it won't let me switch to am fm or CD. Phone won't come though speakers either. Let it sit for 1/2 hour with the key on, still 0%. Called Sirius, they deactivated, reactivated it but still no sound and locked.
Anybody has this before? I had been having Sirius reception and backup camera issues. Does the Sirius antenna wire go through the connector on the park brake pedal? If it doesn't work by morning it's going to Ford. Silence sucks!
Old May 5, 2017 | 07:37 PM
7.3 Powerstroker's Avatar
7.3 Powerstroker
Had it happen to my truck one time pull the fuse for the radio then put it back in should reset it. They are little computers now and freeze up like computers.
Old May 6, 2017 | 04:30 AM
Just Strokin's Avatar
Just Strokin
Often, Sirius sends an update to your radio. It may take a few minutes to complete. Be patient and let it finish. If you interrupt it, it will start again later and you will have the same silence and status shown till it finishes.
You problem might be the Sirius module? I would have Ford check it.
Old May 6, 2017 | 05:56 AM
senix's Avatar
senix
do a master reset.
Old May 6, 2017 | 08:37 AM
Ferguson65's Avatar
Ferguson65
Originally Posted by senix
do a master reset.
Are there instructions for that in the owners manual? Or do I need to look elsewhere?
Old May 6, 2017 | 10:24 AM
senix's Avatar
senix
Look under settings. The little gear on the front of the screen. You should find it.
Just push the reset and it will do the rest.
May have to repare your phone and reset your radio stations.
Old May 6, 2017 | 02:06 PM
Ferguson65's Avatar
Ferguson65
Tried the master reset first. No luck. Drove to dealer and made appointment to have it looked at, needs state inspection anyway. Couldn't see how pulling the fuse would help if a master reset didn't. But I tried it anyway, and I'll be damned it worked! Happy to have the radio back! Thank you 7.3 Powerstroker!
Old May 6, 2017 | 04:46 PM
senix's Avatar
senix
Amazing, but that is electronics.
Old May 6, 2017 | 10:59 PM
k7lvo's Avatar
k7lvo
Speaking as someone who has been an electronics technician long enough to watch solid state take the place of tubes, the is NO reset as MASTER as power cycling - also known as "pulling the fuse."
Old May 7, 2017 | 11:06 AM
7.3 Powerstroker
No problem glad it worked for you. Had a ford tech tell me about that cause it kills all the power to it and resets it.
Old May 8, 2017 | 12:50 PM
Ferguson65's Avatar
Ferguson65
For what its worth, the dealer just called and there is a TSB on this. He said it's very limited on info but does say to replace the radio. I guess this will mean the ESP I bought has already paid for itself. $50 deductible and I'll have it back tomorrow!
Old May 8, 2017 | 01:43 PM
Dakster's Avatar
Dakster
That siriusly sucks...
And I'd be siriusly pissed.
Basically, their update bricked your radio and it should be on their dime, not yours...
Old Apr 24, 2019 | 08:15 PM
Chris Chalkley's Avatar
Chris Chalkley
Thanks for the fuse tip. That worked for me with my 2013 Ford Sync system. It also fixed a lingering problem where I couldn't use the paddle controls to navigate FM radio stations. I guess pulling out the fuse is the equivalent of a Ctrl-Alt-Delete to reset those systems -- the "restore to factory settings" option did nothing but delete my saved data.
Old Apr 24, 2019 | 10:06 PM
Just Strokin
I have loaded v3.10 of Sync 2 with no problems. It has been working flawlessly for a few months now.
CMill250
6.7L Power Stroke Diesel
17
Oct 31, 2019 10:17 PM
jhaines10
May 10, 2015 02:10 PM
cj70mach1
Dec 6, 2012 11:05 PM
bigsix
Feb 15, 2001 08:10 PM
