Strange Idle?
Old May 5, 2017 | 01:40 PM
Jma7959's Avatar
Jma7959
Strange Idle?
I have a 1996 f250 4x4 with a 7.3. I have replaced the low pressure melling pump, the high pressure pump, fuel pump, fpr spring, ipr, icp and both undervalve cover harness and all four pig tails and my idle in park is erratic you can feel it in the truck. I can put it in gear and it stops. What do I need to look for now? Please help as this is driving me crazy
Old May 5, 2017 | 01:45 PM
knottyrope's Avatar
knottyrope
have you driven it 100 miles after doing all of that work?
are you sure there is no air in the fuel?
is fuel pressure at least 45 PSI during a WOT run in third?
clean FPR Screen?
possible you have a bad injector, can you do a buzz test and CCT?
Old May 5, 2017 | 01:49 PM
Jma7959's Avatar
Jma7959
I've done all of those things, the buzz test and cct come back good no faults no check engine light. I'm a diesel mechanic by trade and this has got me stumped.
Old May 5, 2017 | 02:11 PM
knottyrope's Avatar
knottyrope
have you tried to unplug an injector one at a time to see if only one is misfiring?
Does it run rough in neutral as well?
Old May 5, 2017 | 02:19 PM
Jma7959's Avatar
Jma7959
Yes I have unplugged them one at a time and all are working, Ill check and see if it idles fine in neutral. Should I start it in neutral or in park to check it? If it idles fine in neutral you think the trs is going out?
Old May 5, 2017 | 02:22 PM
knottyrope's Avatar
knottyrope
TRS might need adjustment if it idles ok in N
Don't matter where you start it
Old May 5, 2017 | 02:28 PM
Jma7959's Avatar
Jma7959
How do you adjust it? I thought it was preset at the factory.
Old May 5, 2017 | 02:36 PM
knottyrope's Avatar
knottyrope
my bad, I was thinking of the one I replaced on a chevy this winter
does it idle better in N?
Old May 5, 2017 | 02:38 PM
Jma7959's Avatar
Jma7959
I haven't checked it yet I will let you know in about 20 minutes or so.
Old May 5, 2017 | 03:25 PM
Jma7959's Avatar
Jma7959
Isles the same in neutral as it does in park.
Old May 5, 2017 | 03:31 PM
madpogue's Avatar
madpogue
Have you tried STARTING it in neutral?
Old May 5, 2017 | 03:35 PM
Jma7959's Avatar
Jma7959
Yes does the same thing
finallyo3gt
45
Jul 12, 2016 02:34 PM
jstarline1
May 17, 2016 07:43 AM
southtexasidi
Dec 19, 2012 10:28 PM
2006powerstroke90
Mar 29, 2012 07:15 AM
Jaaaaaaackman
May 31, 2006 07:47 AM
