fuel pump pressure
Old Dec 18, 2012 | 09:59 PM
southtexasidi's Avatar
southtexasidi
fuel pump pressure
my truck has been running like its running out of fuel lately, symptoms including: rough idle, surging at cruise speed, high idle, idle speed surging, basically runs like crap. I also notcied while accelerating through 2nd gear the truck tries to ''run away'' for a sec, i then let out of the throttle and continue to accelerate. I think the truck is starving for fuel, thats what it feels like at least.
I plan on checking my fuel pump pressure tomorrow. Im going to check it from the hard line from the fuel pump to the filter housing. How much pressure should I see?
Old Dec 18, 2012 | 11:17 PM
hairyboxnoogle's Avatar
hairyboxnoogle
I cant remember what the exact pressure is, but i would expect 5-7psi. You can check at the schrader valve. Ya what youre descibing sounds like its sucking air / starving for fuel.
Old Dec 19, 2012 | 12:16 AM
RacinNdrummin's Avatar
RacinNdrummin
6psi is the best pressure I have tried. You get the most out of your pump.
Fuel pressure can cause your symptoms, but so can air intrusion...
Old Dec 19, 2012 | 06:47 AM
southtexasidi
thanks, and Im going to check for air instrusion too. Ill let yall know what I find later today
Old Dec 19, 2012 | 10:15 AM
hairyboxnoogle
Copy cat... lol
Old Dec 19, 2012 | 12:45 PM
joshofalltrades's Avatar
joshofalltrades
and make sure you change your filter if you haven't already - don't want to neglect the easiest first step
Old Dec 19, 2012 | 10:28 PM
southtexasidi
Checked pump pressure today, read 3 psi at the shrader. Replacing the pump tomorrow after school, Ill change the filter too while Im at it. thanks for the help yall, hopefully Ill get the ol girl runnin good again
jspringator
Modular V10 (6.8l)
Oct 1, 2012 07:37 AM
MrJames159
Nov 11, 2010 08:15 PM
rjlucas
Dec 24, 2007 10:23 PM
jtharvey
Jan 8, 2006 11:12 AM
switzee
Bronco II
Aug 23, 2005 04:11 PM
