My horrible english knowledge...
Jack. I was trying to express that when using plastigauge, the crank should not rotate when tightening the housing screws. This causes inaccuracies when squeezing the measuring cord.
Plastigauge? Pickup a set of telescoping bore gauges and micrometer.
Load your main caps and rods with the bearings and torque to spec.
Mic the crank, record measurements.
Use bore gauges check bearings in a few spots.
Subtract measurements for clearances. Compare those to spec.
Numbers don't lie.
TooManyToys. Do you still have one of those steel engine lift plates for sale? Went looking on eBay and cannot find that link. My 6.0 needs to be resealed spraying oil all over the bottom of the truck, lol.
Thanks, Joe
I have one that I would be willing to let you rent or buy.
I'm trying to DM you and it will not let me. Interested.
You don't have enough time/posts to send a PM yet. That is why your having problems.
He can always send the info to you by PM and then if you are OK with it take it to Email.
