Sponsored by: Auxito
sticking power window
Old Sep 2, 2003 | 08:11 PM
ob1bnl's Avatar
ob1bnl
Unhappy sticking power window
Hi All,
Just wondering if anyone else has had this problem: In the last week or so, my driver's side power window is getting "hung up". When I push my window button to auto, so that it opens automatically, it gets hung up about 1/3 of the way down, and the auto mode shuts off. Is there something that I need to clean or fix inside my door that is causing this? Not a huge issue, but I want to fix it before I burn out my p/w motor.
Thanx, OB
Old Sep 2, 2003 | 08:39 PM
AegisSailor's Avatar
AegisSailor
Are you saying that if you don't use the auto function, you can get it down all the way?
Old Sep 2, 2003 | 08:46 PM
ob1bnl's Avatar
ob1bnl
yes....without auto it will go down......but slows down about 1/3 of the way down.....almost to a stop. I'm sure this will decrease the life on my motor, so I want to fix it now.
OB
Old Sep 2, 2003 | 10:08 PM
Racerguy's Avatar
Racerguy
Take some WD40 or silicone lube spray and spray the window runs at the front and back of the windows. Usually doing this will help clean out the junk that gets in there and lubes it as well.
Old Sep 2, 2003 | 10:27 PM
ob1bnl's Avatar
ob1bnl
so WD or silicone spray where the window rides? so this doesn't involve dismantling the door panel or anything?
Thx, OB
Old Sep 2, 2003 | 10:35 PM
Racerguy's Avatar
Racerguy
Right. Just roll the window down and spray where the window rides in the channels at the front and back.
Old Sep 3, 2003 | 08:05 PM
ob1bnl's Avatar
ob1bnl
Thumbs up sticking power window
That was just the thing.....sprayed some silicone spray in there.....now it works perfectly
Thanx for the info. Dave......right on the money
Old Sep 3, 2003 | 08:10 PM
Racerguy's Avatar
Racerguy
Good to hear
It's something that you might have to do every once in a while but it's quick and easy.
darmento
Aug 2, 2016 03:07 PM
DrZoom
Ford Truck Parts for Sale
Dec 14, 2015 04:19 PM
RubberDuck
1983 - 2012 Ranger & B-Series
Nov 17, 2015 07:33 AM
HouseFullofFords
Electrical Systems/Wiring
May 26, 2014 05:18 PM
bigk_54
Jan 14, 2011 05:43 PM
