Amsoil
Old May 14, 2017 | 10:23 AM
  #31
js139's Avatar
js139
Originally Posted by HeavyAssault
3) The claims of increased MPGs and more power are not demonstrated across all product lines.
4) Extended drain intervals are not as they claim since you need to add 1-2 qts of new fluid. From Amzoil: Note: 2007-2010 Dodge**, Ford** and GM** turbodiesel pickups are also not recommended for extended drain intervals when using DHD.
AMSOIL Heavy-Duty Synthetic Diesel Oil is recommended for the drain intervals stated by the original equipment manufacturer (OEM).
5) No Amzoil rep will ever stand up for the product claims. If you want to face a real challenge with your product PM me.
6) Did I mention if it was REALLY that good we all would already be using it. See the above.
As as noted earlier in this thread, everyone has their own opinion and bias on this topic. Thank you for stating yours.
as for increased mpg, most vehicles I've added amsoil to did see mileage gains. The vehicles I didn't see mileage gain were heavily geared (like my wheeler with 5.33 gears). That is an off-road vehicle only and the mileage gains were not noted when I'd run it on the street.
as for the drain intervals, this was impacted by the emissions systems on these truck. The fuel dilution issues caused significant issues with the truck among all oils, which is why all oil manufactures recommended early changes.
i am a dealer and I do stand by the product. I don't try and grow this business as I have other options to follow. That said, I do recommend this product 100%. Sounds to me like you had a bad experience and resent that. Those are things that can't be avoided. Sorry the rep at the time wasn't able to satisfy you.
i know amsoil is a good product, which is why I am still a user. I also fully recommended it. The op asked people opinions on it, so we shared, as did you. Thanks for sharing. Despite your experience, I have zero issues using or recommending the product.
Old May 14, 2017 | 12:51 PM
  #32
HeavyAssault's Avatar
HeavyAssault
I'd expect this response from any Amzoil guy. If you want to bash mine then go ahead and try. I never mentioned any rep never being able to satisfy my complaint. Most are not directly employed by Amzoil so I don't fault them, I just ask them to stand up to the suggested claims of the product. Very few will do anything, and Amzoil corp surely doesn't do squat.
This is the funny part: If the AMSOIL lubricant is defective in materials, design and workmanship, AMSOIL will (1) replace the defective lubricant; and (2) at the option and cost of AMSOIL, repair or replace components damaged by the defective AMSOIL lubricant.
It's their OPTION to repair/replace .....LOL
Of course the remainder of the "warranty" I want to post is a tad much to post here but it's an interesting read. Could it happen sure, MAYBE your motor will get paid for but hope you can let it sit till the check comes in.
Old May 14, 2017 | 03:26 PM
  #33
HRTKD's Avatar
HRTKD
Show me how that is different for other brands.
Old May 14, 2017 | 03:30 PM
  #34
HeavyAssault
I never said it was different. Last I recall no sales person from Mobil 1 or Shell uses it as a selling point.......unlike Amzoil.
That's my point....it is the SAME as all others. Nothing special.
Old May 14, 2017 | 04:47 PM
  #35
willydmax's Avatar
willydmax
Not sure why you are so anti Amsoil. Sounds like you had a bad experience with it. Just to be clear the quote in bold doesn't really have much to do with our discussion here. Amsoil doesn't even list the DHD (5w30 diesel oil) as recommended oil for any '07-10 Powerstroke, Cummins or Duramax. Opinions on oil are quite varied. I have had great luck with Amsoil and will say this much. If you were my customer and had issues with Amsoil I would try my best to find a solution. Just my $.02
Old May 14, 2017 | 05:51 PM
  #36
HeavyAssault
I guess there is an echo in here...repeating what I posted from the Amzoil site...guess they don't keep their info up to date.. I was demonstrating the pull back on extended drain intervals. I picked two of their "diesel" oils at random. Nothing here (AMSOIL Signature Series Max-Duty Synthetic Diesel Oil 5W-30)disqualifies use of this oil, just their little quick oil selector tool doesn't pull it up.
In the end I guess we have established it's more expensive, hard to get, doesn't always improve MPGs, doesn't allow for extended drain intervals, AND has just the same warranty as any other company out there. SO.....why is it so much better? The name? The bottle? The buying experience? I guess I'm missing it......Thanks for allowing me the opportunity to defend my simple original opinion. I didn't expect to get beat up about it since all the facts are there in plain sight.
Old May 14, 2017 | 06:02 PM
  #37
js139's Avatar
js139
you can please some of the people some of the time, most of the people most of the time, but you can't please all of the people all of the time. You like the oil you like. I like the oil I like. Neither of us will change our minds. It isn't worth an argument either way. The op asked opinions. We both shared them. Nicely done.
Point and case, this is why I stated people have their own strong opinions both ways.
Good day!
Old May 21, 2017 | 09:55 AM
  #38
Dan1954's Avatar
Dan1954
New diesel owner here. I'm at the 3000 mile mark & want to get my first oil change done for my 2017 F350 PS. I'm an Amsoil user for my other engines & will be using it in my new truck. My question is while I prefer to use full synthetic motor oil should I wait until the second oil change to use a synthetic oil? Do these come from the factory with regular oil, a blend or full synthetic? Thanks
Old May 21, 2017 | 11:51 AM
  #39
Overkill2's Avatar
Overkill2
You should have the Motorcraft 10w30 in your 6.7, I would think...unless someone who knows more than I can definitively answer and confirm/deny that.
They make a 0w40 and a 5w40 full synthetic diesel oil and also make dino 10w30, 15w40 and 30w. But the recommended normal use weight is the 10w30. You can find that stuff here.
They also have a list of approved brands of oil Meeting Ford WSS-M2C171-F1 spec there.
Old May 23, 2017 | 12:46 PM
  #40
shortride's Avatar
shortride
Using a higher grade engine oil such as Amsoil full synthetic will not necessarily be better for the engine in your truck. If you continue to use the factory recommended engine oil along with proper maintenance you will most like never realize any difference. Amsoil full synthetic engine oil meets or exceeded the Ford Motorcraft specifications. The only real way of find out the difference or benefits if any by using Amsoil or any brand of engine oil is to send a used engine oil sample to places like Blackstone Laboratories to have it analyzed. If the results of the lab test has convinced you that you should change then go for it. Otherwise you will only continue to read more information like this on the internet.
Old Jul 26, 2017 | 07:08 PM
  #41
drptop70ss's Avatar
drptop70ss
Sorry wrong post
Old Jul 27, 2017 | 10:15 AM
  #42
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Folks, I posted the list of oil that meets Fords WSS-M2C171-F1 standard here - https://www.ford-trucks.com/forums/1...ngine-oil.html - someone else found one that is newer than mine.
The other interesting thing I recently learned is that oil produced prior to 2016 and has only the CJ-4 in the "API Circle" is "ok". I also posted in the thread above a letter from Ford around the 2016 CJ-4 being "ok"
Old Jul 28, 2017 | 08:04 AM
  #43
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Dan - I would not mess with what oil you use until you get to at least 10 - 15,000. Stick with Motorcraft's Diesel oil. I also think unless the truck is telling you to change the oil I think you're a little early. I as well am a new diesel owner - couldn't afford a 2017 - went with a low milage 2013 - anyway, what I've learned is that 5 - 7,000 miles is not uncommon. Like you, coming from the gasser world, I changed my oil religiously at 3,000. I've spoken to the service manager and a bunch of the diesel mechanics at the dealership I take my truck to and all have said "let the truck tell you when to change the oil". That being said, why I haven't done this sooner I'm shaking my head but but for the last 21,000 miles my truck has told me to change my oil at slightly over 7,000 miles. This time I'm going to send a sample off to Blackstone. I bought one of those ez-drain oil plugs and am going to send them a sample at 3,000 and 5,000 in hopes of finding the right change interval.
Old Jul 28, 2017 | 06:26 PM
  #44
whooboy's Avatar
whooboy
As I remember the effect of the oil that doesn't meet Ford's requirements is long range, probably not until over 150,000 miles before it is significant. I may be wrong about that. I think that when we think of an engine "failure," we are envisioning a failure like we see at the NASCAR races. But I think what we will see is a gradual degradation, therefore not causing anyone's warranty to kick in. And...if we trade in early, we may not see a problem at all.
I understand peoples' loyalty to brands. I have those I like too, but I think that most oils meet basic API standards and are probably just as good as any others' oils. Especially if you change oil often. Now, I'm old school, really old school, so I'm staying with the 5,000 mile oil change, and I'm staying with Motorcraft.
As to fuel mileage: I guess I'm the only one who gets 9.5 to 10.5 mpg in town. Everyone else seems to be making fuel. Highway mileage? I only get on the highway with a 5th wheel attached. Then I get 9.5 to 11.0 mpg. I don't think a different brand of oil is going to change that.
Old Jul 28, 2017 | 07:14 PM
  #45
ruschejj's Avatar
ruschejj
Gotta love oil threads.
We all have different duty cycles too. My 2015 truck has 170,xxx on it and by the end of next week it will be 171,xxx. I change the oil when the truck dings at me, which is around 7500 miles, which is about every 5 weeks. For me, using a high priced boutique oil would be stupid. Just using shell T-6 costs me about $70/month, fancy stuff would be $200 bi-monthly? No thanks.
Fuel and oil for some people is a real expense on a weekly basis. Even if I changed oil at 15,000 mile intervals I'd be buying 18 gallons/year. I use the cheapest 5w-40 I can find which is valvoline at present. I used T-6 since 2011 and never has any reason to change.
