Inner Fender Paint Color
Some have have had them powdercoated grey or grey/silver vein. You could try your choice of color plus clear coats.
I shot mine with Rustoleum 500° engine enamel.. satin black.
A fellow FTE member said " I used Rustoleum Industrial Aluminum spray paint, comes in a 33% more can. Used less than half can to do inner fenders for around $12 a can, the primer is about $8. It dries really fast, goes on thick, and never gets runs. I used Rustoleum Industrial spray paint for everything. I have painted all kinds of things like the fire walls on a 68 cougar xr7, 1956 ford, 1955 ford Crown Victoria, numerous parts, and a whole van for a friend.
It goes on really good with one coat, lots of coverage, 2nd coat has to be within an hour, or after 48 or something, I just do 1 coat. I tried other spray paint, but this is my favorite, for a rattle can job anyways. It's enamel, so it takes long time to cure. It does dull, and in a year I do expect to see rust coming out again, From Acklands Grainger."
Here are his pics, it might be a little to bright IMO?
Thanks. A word of caution on the regalvanizing. I looked into that and wasn't very confident that I would like the results. All the samples I saw just looked like they had been sprayed with gray primer.
The shop I took my parts to for powder coating in black. I asked them about powder coating the inners in silver/for the galvanized look. They didn't want to do it. Main reason they said was they we're worried about adhesion problems and explained all the reasons why. So I just had them give it a light sand blasting to clean them up for me. Then I prepped and painted them.
Later, Shortbox4x4
1974xlt
13
09-06-2017 10:31 PM
good to doo
01-25-2015 12:37 AM
