Sound System?
Old May 2, 2017 | 12:29 PM
cj_1776's Avatar
cj_1776
Sound System?
I am planning to upgrade the speakers in my 1997 crew cab f250. The problem is I have no idea what size speakers I need and how to install them? Does anyone have advice on this?
Old May 2, 2017 | 12:34 PM
Motorhead351's Avatar
Motorhead351
Go to crutchfield.com, they have diagrams and instruction, for replacing factory speakers, also size of. If for some reason you cant find the information email them or do the live chat.
Old May 2, 2017 | 12:37 PM
Brian Donoghue's Avatar
Brian Donoghue
For cc lb the fronts are 6.5" and rear are 6"x8". Ive heard rockford speakers are fantastic speakers. Im going to need to do both my trucks (one has 2 extra speakers that were installed in the rear door.
Old May 2, 2017 | 12:42 PM
cj_1776's Avatar
cj_1776
It should be the same for CCSB correct?
Old May 2, 2017 | 12:44 PM
cj_1776's Avatar
cj_1776
Should I invest in speakers to put behind the seat? I will be running a sundown SA-12 sub which will be very loud so I was wondering if I need to accommodate
Old May 2, 2017 | 01:32 PM
Brian Donoghue
Yea it should be. The only difference would be between the cabs for the changes of speaker size. My speakers in both of my rigs just blew.
Old May 2, 2017 | 04:25 PM
seagiant's Avatar
seagiant
Hi,
I have a single cab and have 2 10" woofers in a special made box behind seat...
And then a tweeter/ midrange in the doors at the original OEM speaker locations!
I have a Alpine Head unit with a small 80 watt amp!
Amp is under the seat.
This works VERY well for me, although admittedly, would not win any competitions!!!
Old May 2, 2017 | 07:52 PM
Fastback460's Avatar
Fastback460
X2 on going the Crutchfield.com
Better yet give them a call, just tell them what you're looking to get out of your stereo system and they'll hook you up with the best setup and even save you from buying stuff you don't really need. Plus great lifetime customer service. They really know their stuff.
Old May 3, 2017 | 10:16 AM
animator's Avatar
animator
I replaced all of my cab speakers with kicker units from Crutchfield. They've got a great website that will help you determine what fits, and what fits with modification. They also include the correct pigtails to hook directly into your factory speaker harness without cutting/splicing.
I'll be building a box and adding subs and amp that will most likely come from crutchfield as well...
Old May 3, 2017 | 11:03 AM
Azryael's Avatar
Azryael
I need to do this as well... PO says he replaced the speakers, but they sound so... cheap. Like those old SONY external laptop speakers I have somewhere.
Old May 3, 2017 | 11:37 AM
cj_1776's Avatar
cj_1776
What brands are good? I was planning on getting some Rockford Fosgate 6.5" 3 way speakers
Old May 3, 2017 | 11:58 AM
Azryael's Avatar
Azryael
I have Kenwood eXcelons in my Durango, not sure if they have them in the sizes we'd need, but they sound great! They have a bit of everything, good clean mids and treble, and enough bass for my taste to not even require a sub.
I've used some Helix stuff I wasn't really happy with; I've also run Alpine and various Pioneer setups with good results.
JVC was another brand I didn't care for.
Crutchfield is the only way to go when it comes to getting your needs met. Call them and tell them exactly what sound you're looking for. Often times they'll ask you what you listen to most to tailor the sound to the majority of what you listen to.
Old May 3, 2017 | 12:01 PM
cj_1776's Avatar
cj_1776
Does anybody have experience with subs? Where do you usually put your box?
Old May 3, 2017 | 02:58 PM
Fastback460
Typically the subs and amp would be installed behind the seat.
But seriously give Crutchfield a call, they install systems in trucks like ours all the time. They will be able to answer any and all of your questions, probably better then anyone here can.
Old May 3, 2017 | 03:01 PM
Fastback460
Does it still have the original radio? They can make even the best speakers sound bad.....lol
