Window felt (sweeps)
Old Apr 30, 2017 | 11:51 AM
dcmania's Avatar
dcmania
I ordered 2 sets of anti rattle window felts for my '59. It looked like it should be a pretty straight forward install...line up 5 clips to 5 holes and press! BUT, the window doesn't roll down quite far enough to clear-the clips kind of stick out a little bit.
Anyone have an easy install tip or do I have to open up the door to drop the window regulator?
Thanks!
Old Apr 30, 2017 | 01:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Drop the window by removing the nylon window roller that clips onto the stud of the regulator, then fits into the window channel that the glass is adhered to.
Old May 1, 2017 | 06:58 AM
willowbilly3's Avatar
willowbilly3
Just had mine apart to put in a new glass. It's pretty easy but not a bad idea to have new roller on hand. The clip is a little tricky and easy to have go flying. Mine went inside the door and I still couldn't find it (didn't look that hard 'cuz I had a new one). It's also a good time to take the regulator out and do a good clean and lube job on it. I use spray white lith on the regulator and the more stiff Lubriplate white grease on the roller. It's buttery smooth now.
Old May 1, 2017 | 09:14 AM
NumberDummy
Drop the window by removing the window roller that clips onto the stud of the regulator, then fits into the window channel that the glass is adhered to.
BA-7023240-A .. Window Roller / Obsolete/Reproduced?
1957/60 F100/1100 // 1952/58 Ford Passenger Cars / 1955/60 Thunderbird // 1961/66 C Series Tilt Cabs.
GREEN SALES CO. in Cincinnati OH has 10 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 3,766 = 800-476-9653.
Old May 2, 2017 | 05:50 AM
willowbilly3
I think I got my off ebay, repops but not bad looking. My originals were all metal.
New 1953 58 Ford Window Rollers Mainline Thunderbird Fairlane 59 60 F100 F250 | eBay
davewave649
13
Feb 19, 2013 03:39 AM
rwdfan
Apr 23, 2011 03:38 AM
ty20404
Jun 24, 2008 05:26 AM
fmc400
16
Mar 16, 2008 12:29 PM
imlowr2
Jun 26, 2006 10:12 PM
