66 parts
Old Apr 29, 2017 | 11:50 PM
Jimmy nz's Avatar
Jimmy nz
66 parts
hi all im coming to california in june and am hoping to pick up a few parts for my truck can anyone recommend any dismantlers parting these trucks out .i need a catch/lock for the bedside toolbox among other bits there is nothihg available here in new zealand
Old Apr 30, 2017 | 08:41 AM
resonateur's Avatar
resonateur
Jimmy:
Turner auto wrecking in Fresno is the largest dismantler, specializing in older vehicles, that I'm aware of. Accordingly, their prices will reflect their awareness that vintage parts can command a premium. Check their website...amazing, about 1000 acres! They can also tell you by phone if they have what you're looking for, as can most yards, so you don't spend so much time searching. Most of the smaller (cheaper) dismantlers here in the central valley who had a good stock of old vehicles are gone. The other thing to consider is that the dismantlers are good places to find large parts like chassis, suspension, sheet metal and those would be the hardest parts for you to take back with you. Let me know if I can be of any assistance.
Old Apr 30, 2017 | 11:39 AM
daveengelson's Avatar
daveengelson
IMO, Central Ca. likely will have more of a selection when it comes to early model trucks?? resonateur listed couple options; there's also 'Pic n Pull' offer a 'vehicle finder' website, enter vehicle info, buyer's zip code and they provide a list of vehicles that match, and map of the salvage site.
Posting website as example only. Depending upon where in Ca. U intend visiting, suggest select zip codes for along the route and run a 'vehicle finder', before leaving.
Pick-n-Pull » Check Inventory
Old Apr 30, 2017 | 11:11 PM
Jimmy nz's Avatar
Jimmy nz
66 parts
Thanks for the replies I'm coming for 3 weeks I intend to buy another truck to drive around and fill up with parts then send it home .I'm looking to get disc brake conversion and power steering among other things so it maybe I should look for a later donor truck to dismantle
Old May 1, 2017 | 10:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Jimmy nz
Thanks for the replies I'm coming for 3 weeks I intend to buy another truck to drive around and fill up with parts then send it home.
I'm looking to get disc brake conversion and power steering among other things so, maybe I should look for a later donor truck to dismantle.
1973/79 F100 2WD; 1975/79 F150 2WD
1975/79 F100 2WD: Manual disc brakes were standard equipment, power disc brakes were optional.
P/S was optional for all the above.
ford2go
General Automotive Discussion
May 17, 2011 08:19 AM
Rolojero
May 13, 2009 04:29 AM
CN Spots
Sep 22, 2007 10:24 PM
Franken-Truck
Virginia Chapter
Dec 17, 2004 08:41 PM
fredscasa
May 27, 2002 10:20 PM
