160 MPH speedometer for a 1966 F series??
I got a hold of this in a batch of flathead parts. It's a 1966 speedo alright - part number C6TZ-17255-F. I can't find it in the corresponding Ford Truck parts book.
as anyone ever seen one? What could have been the reason? I don't think the cop car speedos went that high.
This speedo was not used on any car.
If the number is marked on the back of the speedo, it may be ID engineering number C6TA or C6TB or C6TF-17255-F
The round speedo was used on 1961/66 F100/1100 & C Series Tilt Cabs; 1961/67 Econoline; 1963/69 N/NT500/1100; 1966/77 Bronco; 1967/69 F800/1000.
There's no such part number of C6TZ-17255-F where did you find it?
The number came off the box it was in.
Any guesses as to the reason for a 160 mph speedo on a truck?
1975/77 Bronco speedo reads to 100 MPH
With a 1966 part number prefix (C6TZ), it could have been originally for a 1966 Bronco.
Some people assume that with a T in the part numbers prefix, that the part fits only a truck.
Awhile back, a clueless ebay seller listed a C6TZ-18813-A antenna kit, said it fits 1966 F100. BS! It's for for a 1966/77 Bronco.
I find that happens a lot. I have a shelf of cluster gears tagged 8L-7113. Can't find that part number nor can I find any gear that matches the tooth count.
Thanks for taking a look.
I don't have a 1949/51 Lincoln Parts Catalog, but Green Sales probably does. You could call 'em and ask.
8L is the part number prefix for 1949 Lincoln/Lincoln Cosmopolitan. 1949/51 Lincoln's were available with the Borg Warner T-85 Overdrive and this may be what these cluster gears are for.
And Mrs69 questioned my desire to hang onto ALL of these "old books".
Isn't the letter "Z" a speed performance part suffix? Maybe this was a NASCAR speedo and not regular production?
I would assume it is in Kilometers per hour
Wonder if it was for Mexico or further south as most of Central and South America have used the Metric system since the 19th century.
This means some interesting gauges clusters were available for the 57 body style.
See pics below.
1963 F100 and 1969 F100 gauge clusters
