360 v. 390
Old Apr 29, 2017 | 08:01 PM
Tan '69's Avatar
Tan '69
360 v. 390
I'm wondering what the torque numbers on these two engines are and any other cool/interesting fact on them
Old Apr 29, 2017 | 09:59 PM
HIO Silver's Avatar
HIO Silver
You've made a statement. Is that yer passive way of asking a question?
Old Apr 30, 2017 | 09:01 AM
willowbilly3's Avatar
willowbilly3
One of the reasons so many 360s get passed off as 390s is that there is very little "seat of the pants" difference in the way they feel.
Old May 1, 2017 | 12:20 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Until you're need deep in the carb in 2nd gear at 6,000 rpm and need 15 more HP to whoop up on that mustang......
Old May 1, 2017 | 02:01 PM
HIO Silver's Avatar
HIO Silver
Posted on Wikipedia:
360 Truck[edit]
The 360, of 360.7 cu in (5.9 L) actual displacement, was introduced in 1968 and phased out at the end of the 1976-year run; it was used in the Ford F Series trucks and pickups. It has a bore of a 390 (4.05 inches (102.87 mm)) and used the 352's 3.5 inches (88.90 mm) rotating assembly. 360s were also constructed with heavy duty internal components for truck use. Use of a standard 352/390 cam for use in passenger cars along with carburetor and distributor adjustment allowed the 360 to give performance similar to that of the 352 and 390 car engines. Rated at 215 bhp (160.3 kW) at 4100 rpm and 375 lb·ft (508 N·m) of torque @2600 rpm (2-barrel carb, 1968). The 360 used the same block, heads and other parts as a 390, this makes them indistinguishable from each other unless the stroke is measured.
360 Truck engine configurations and applications[edit]
  • 2V, 8.4:1
    • 215 bhp (160.3 kW) at 4100 rpm and 375 lb·ft (508 N·m) at 2600 rpm
      • 1968–1971 Trucks[
    • 196 horsepower (146 kW) net at 4000 rpm and 327 lb·ft (443 N·m) at 2400 rpm
      • 1972–1976 Trucks"
26
Jun 7, 2020 05:05 PM
eclectix
16
Sep 4, 2015 03:20 PM
muddyford75
Dec 27, 2003 08:45 PM
1975 f150 360
Jul 8, 2003 12:45 AM
DutchmanAZ
Apr 22, 2002 01:08 PM
