Clutch maybe
Old Apr 28, 2017 | 09:21 AM
Treeguy604's Avatar
Treeguy604
Clutch maybe
So last weekend I was wheeling and my truck all of a sudden seem to loose power but the engine ran completely fine what leads me to the clutch was it wouldn't go in first second and all of a sudden she divided to catch and seemed like the truck would only go slow as the engine revved up the truck wouldn't go any faster just kinda stayed the same speed if anyone could help me I'm so lost today I'm taking the clutch apart to take a look and see for myself but has anyone had this problem I had to limp it 80 km home and had to take first gear up hills as I love on a few gnarly hills thanks jr
Old Apr 28, 2017 | 03:57 PM
madpogue's Avatar
madpogue
Could also be the transfer case. Have you tried 4LO?
Old Apr 30, 2017 | 07:02 AM
tjc transport's Avatar
tjc transport
i ain't rite
when my 88 did that, the dual mass flywheel failed.
Old Apr 30, 2017 | 04:40 PM
cadunkle's Avatar
cadunkle
Sounds like it's slipping... You can check slave cylinder travel and be sure it's releasing fully but if it still slips you'll need to pull it apart and replace the clutch.
Old May 1, 2017 | 07:17 AM
tecgod13's Avatar
tecgod13
I had a similar experience. Clutch still seemed fine on flat ground, but 'slipped' going up hill.
There is a slip clutch built into the dual mass flywheel that is supposed to protect something from braking, but in reality once it slips, the DMF is toast and will continue to slip worse and worse.
Old May 1, 2017 | 02:03 PM
tjc transport
i ain't rite
exactly what happened. the clutch was in perfect shape and still looked like new. but the disc in the middle of the flywheel came out in pieces.
and the flywheel fell apart in two pieces when it was put on the ground and rolled out from under the truck.
Old May 1, 2017 | 09:34 PM
tecgod13's Avatar
tecgod13
Wow that's real bad Tom!
Mine was all one piece when it came out. I did take it apart to see what the slip part looked like and you could tell it had worn.
Old May 2, 2017 | 03:53 AM
tjc transport
i ain't rite
mine was used and abused for 320,000 miles though. for the second 100,000 miles it pulled 22,000 lbs all over the ny, nj, pa tri state area for close to three years.
thordehr
25
May 19, 2016 09:17 AM
d3ryl
Apr 26, 2009 08:08 PM
redrocket98
1997 - 2003 F150
Apr 15, 2008 08:58 PM
95_Ford XL
Mar 18, 2003 09:14 PM
bcsbadboys
18
Dec 3, 2002 03:11 PM
