Sponsored by: Auxito
clutch or not
Old Apr 15, 2008 | 11:02 AM
redrocket98's Avatar
redrocket98
clutch or not
my 1998 f150 4x4 has a 5 speed in it with a 4.6L.
i can put it in gear and it will move at a high rpm moving very slow
i can only get about 60kms out of it.
Old Apr 15, 2008 | 11:12 AM
monckywrench's Avatar
monckywrench
If the engine runs normally, the clutch is done.
Have the flywheel resurfaced when you do the clutch, and inspect the clutch hydraulics for leakage. A common cause for toasted clutches is a hydraulic problem (slave cylinder usually) that doesn't allow full clutch release. If not corrected, the new clutch gets fried too.
Old Apr 15, 2008 | 01:58 PM
redrocket98
the shop guy seems to think my tcase gear selector broke and no its stuck in low gear. were hoping its the fork that shifts the 4x4 so i can get my 2 hi back
Old Apr 15, 2008 | 04:17 PM
sclariat's Avatar
sclariat
If you were stuck in low range, you'd know it. what happens when you move the transfer case selector?
Old Apr 15, 2008 | 04:49 PM
redrocket98
nothing seems to happen theres no feeling in the gear selection. truck just seems really torquey haha cant spell. gear shifter says im in 2 hi but its 4low
Old Apr 15, 2008 | 08:31 PM
sclariat's Avatar
sclariat
Your range fork is likely busted or worn right through. Pull the drain plug and inspect the oil...if there is any left that is, lol.
Old Apr 15, 2008 | 08:47 PM
redrocket98
hmm if it still moves in 4x4 should that be a sign that it might only e the fork and not the tcase
Old Apr 15, 2008 | 08:58 PM
sclariat's Avatar
sclariat
The range fork is in the transfer case. It's the one that selects between high and low range. If the stick is in 2 wheel drive mode but the transfer case is in 4 wheel low then I'd have to say there is a problem with the transfer case....or linkage?
