6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
disconnecting fuel lines
Old Apr 26, 2017 | 06:32 PM
Novice Diesel Owner's Avatar
Novice Diesel Owner
How do one disconnect the fuel lines to remove the HFCM so it can be removed and replaced as a whole part? I keep reading all I have to do in pinch the the two blue tabs on the line, push forward, slightly turn one way or the other and then pull it off; Im here to tell you, that ain't working and I would like to get this part changed so I can get my truck back on the road.
So does anyone have the right solution to disconnecting and then reconnecting these lines?
Old Apr 27, 2017 | 08:28 AM
speakerfritz's Avatar
speakerfritz
I had to do the pinch blue tabs and at the same time use two open ends to pull the connector off the fitting.
wildstang
Mar 17, 2010 08:54 PM
MrG4x4
Jul 10, 2008 12:09 AM
CoachRobb
Jul 9, 2007 08:11 PM
moritz1024
1978 - 1996 Big Bronco
Aug 27, 2004 04:59 PM
Jimmy Dean
Jun 28, 2004 09:18 PM
