removing fuel lines
Old Mar 11, 2010 | 08:44 PM
wildstang's Avatar
wildstang
VT Chapter Ldr
removing fuel lines
I am trying to replace the metal fuel lines from the fuel bowl to the flex lines under the engine. I have those stupid plastic slides but not working. What are some better fuel line disconnect slides?
Old Mar 12, 2010 | 04:55 AM
sassydog's Avatar
sassydog
did you clean the crap out of the fittings first before useing the plastic. lots of stuff is packed in there
Old Mar 12, 2010 | 05:07 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
The best that I could. I could not get them to release down by the firewall either and those are clean.
Old Mar 12, 2010 | 07:20 AM
riverrat41's Avatar
riverrat41
The parts stores sell a universal (metal)fuel link disconnect tool.It is made to fit several different sizes.I will try to find a picture.
Old Mar 12, 2010 | 07:27 AM
riverrat41's Avatar
riverrat41
Amazon.com: A/C and Fuel Line Disconnect Tool - 4494, by OTC - OTC - 4494: Home Improvement
Old Mar 12, 2010 | 09:57 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Interesting those go in deep enough for the fuel line? Picture makes them look shallow.
Old Mar 12, 2010 | 11:17 AM
riverrat41's Avatar
riverrat41
I have the metal and the plastic ones.I prefer the metal and they do work.Not very expensive and good to have when you need them.
Old Mar 12, 2010 | 11:25 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I will have to see if I can find a pair around here. A guy I know has a set of plastic ones that sound longer then mine I might try also. He also mentioned giving the line a twist to help break any corrosion between the fingers and the line which I didn't thing to try. He said I could try his metal ones also.
Old Mar 12, 2010 | 11:42 AM
riverrat41's Avatar
riverrat41
Yea...It might take a little persuading once you get the tool in there.Make sure to wear safety glasses or goggles in case the fuel flies when it does come apart....Good luck
Old Mar 12, 2010 | 11:47 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Thanks, I 'll need it.
Old Mar 17, 2010 | 04:24 PM
sassydog's Avatar
sassydog
I made a pair of plyers into those quick relase by welding a next up larger peice of gas line to the plyers then cut in have close around fuel line and slide into fitten, and bitch........
Old Mar 17, 2010 | 08:54 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Do you have a picture to them to get better the idea?
04black5.4L
Mar 9, 2016 06:55 PM
burnthelight88
Aug 3, 2015 07:22 PM
Bad Bad Leroy Brown
Sep 28, 2012 01:45 PM
98-Ranger
1983 - 2012 Ranger & B-Series
Jan 22, 2006 08:12 AM
Travis Peters
Apr 21, 2003 08:53 AM
