2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Diesel Fuel Shutoff after an accident - Reset button?
Old 04-26-2017, 05:25 PM
jm-bc's Avatar
jm-bc
jm-bc is offline
Hi Everyone,
The manual (on page 297-1st printing; 298-2nd printing) refers to the diesel fuel pump reset button that may be required after an accident situation.
"This switch is located on the passenger’s
side of the instrument panel. Open the
front passenger door and remove the small
access panel.
The switch has a red button on top of it."
I cannot find any such button on my truck.
The prior section refers to fuel shutoff for the "6.2L/6.8L" (sic) engines. It appears that the first engine has an automatic fuel pump reset. The second engine leaves me wondering if the whole section is bogus.
Can anyone shed light on this?
Thanks
Jonathan
Old 04-26-2017, 07:46 PM
skanj0's Avatar
skanj0
skanj0 is offline
Originally Posted by jm-bc
Hi Everyone,
access panel.
Thanks
Jonathan
My 2016 powerstroke has the fuel reset button exactly where you are describing. Perhaps Ford didnt update this section of the owners manual for the 2017 trucks?
Old 04-26-2017, 08:53 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
The side panel, lower edge right beside the passengers boots, on the outside edge will have a small panel. It will be hard to remove, amd it should be inside there. I believe you would have to take out the whole lower side panel stretching beneath the dash. If the little red button is out, you push it back in. If you have it out already and can't find it I don't know what to tell you. If your truck is being repaired this should be part of what gets done. I will go pull my manual and see what I can find.
Old 04-26-2017, 09:01 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
See pg 297, picture E163367, I think it's behind the box with all the plugs, which I believe are for the upfitter said if you have them and there is a ton of fuses in there. I can't see in behind well, maybe try a mirror on a stick and a bright flashlight.
MauleOne
02-17-2012 10:25 AM
KC92F150
02-12-2005 08:12 PM
cbr900bikes
1997-2006 Expedition & Navigator
01-25-2004 09:24 PM
Doxy
07-11-2003 11:52 AM
Skipdaddie
02-06-2003 06:50 AM
Quick Reply: Diesel Fuel Shutoff after an accident - Reset button?
