White smoke
Old Apr 25, 2017 | 09:33 PM
Burgesam's Avatar
Burgesam
White smoke
So when I am driving my truck sometimes it roals coal and sometimes it blows white smoke. What's going on?
Old Apr 25, 2017 | 10:53 PM
genscripter's Avatar
genscripter
You might want to cut back on the bean burritos man. With farts like that, you should see a doctor.
Also important is maybe informing us some info on your "truck." Year, engine, turbo or NA, mileage, how long ago you replaced your IP, injectors, fuel filter, etc. When the farting occurs, like when it's cold, or if you are on the highway, etc. Information can help. Or I'll just keep imagining you farting.
DarkOverCast's Avatar
DarkOverCast
My truck does the EXACT same thing, check your intake for excessive oil coming out of the cdr.
​​​​​​​Personally I think mine is just worn injectors, I've been collecting shims so I can rebuild a set I have set back
Old Apr 26, 2017 | 09:07 PM
Macrobb's Avatar
Macrobb
White smoke is retarded timing when in this context.
This can be either due to base timing being retarded, or lack of fuel pressure due to a blockage somewhere, like in the fuel pickup tube in the tank. Of course, a blockage will also result in reduced power.
Rebuilding a set of injectors with new shims and increasing the pop pressure to stock... will make the problem worse, not better.
I'm not saying you *don't* want to rebuild your injectors... But you need to bump the timing to compensate at the same time.
Typically, a worn IP will start having screwy and retarded timing long before anything else fails; it's just kind of how the IPs wear.
tmill28
Jun 22, 2014 11:55 PM
JHoffman93
Nov 22, 2010 10:51 PM
1978fordf250
Nov 3, 2007 11:11 PM
442john
Jul 3, 2007 09:35 AM
seizure911
Apr 18, 2007 05:38 PM
