Demco Hijacker Autoslide 21K DM8550038 install pictures F-350 SB
I wanted to share a couple of pictures on the Demco Autoslider for those who might be considering this option.
I installed on the middle setting 16 3/4". I have not hooked up the Montana 3710 yet so I may need to adjust.
I used one of the thicker spacers on each side for the ford factory prep on the F-350 CC SB SRW 4x4.
I can close the tonneau cover with the hitch head installed.
Very nice! That's the hitch I went with one year ago, and it's holding up well. One thing you might do, is put a light coat of grease on your king pin. Before I did that, I was having troubles getting the hitch to fully close when backing into it. I think it was sticking. Don't need much since the king pin doesn't pivot with this hitch.
Because Demco requires it. The torsional forces put on the morryde pin will cause damage to its sliding mechanism. My buddy just bought the same hitch from the dealer he got his TH from, and they forgot the capture plate. He tells me that pin twists something terrible when turning corners. He has the capture plate on the way. The kit comes with some additional nylon blocks that stiffen the lateral motion while allowing the pin to still perform it's shock absorbing function.
JR58
Fifth Wheel & Gooseneck RV Towing
26
07-01-2013 08:56 AM
