so I've done two oil changes since I've owned the truck for about 2 months now and it still reads over full. Going by the manual the Windsor takes 5.5 quarts and I've also looked at the dipstick and it is a Windsor dipstick so I'm still dumbfounded. We're there different oil pans or dipsticks for the Windsor? It's a 1975 block and no it's not stock to the truck. Just confused in why it keeps reading the way it is when everything else seems to be the norm by looking at it.
Dipstick has an ID number stamped on it, post what it is.
Thats the main thing holding me back with the truck since the motor isnt the stock 302 and the PO did not know what the Windsor came out of. Was the car and truck Windsor different in terms of per say the oil pan or anything else fir that matter? 1 thing i know is that the oil pan bottom has maybe an inch of clearance above the crossmember thats there, figured with the different engine that was what caused it but not too sure.
